Squeaking after springs install?
I got some comptech springs installed in January and ever since then I've had a squeak that seems to come from the back seat. I've heard of people having this problem on their TLs before but I didn't have it until the spring installation. I know they have to remove your back seat to install springs, so I'm guessing something is rubbing due to the way the seat was put back in. Anyone know how to fix this?
it might be the seat want put back properly, although i doubt this could be it, but double check to make sure ur rear seat is secured and put in properly buy liftin the seat portion up and then pushing down on it.
you sure its the back seat... I had squeaking before putting the springs.. and it was the front ball joints. Got em replace (under warranty) while doing the spring install... Now a year later I think they are squeaking AGAIN !!
Hmmm, not sure about Comptech springs, but a few months after installing my Tein SS Coilovers the rear springs/shocks started to squeak whenever I went over bumps.. So the next time I was adjusting the ride height, I took some silicone lubricant spray and sprayed some onto the shocks. No problems since then!
Yes .. but mine was squeeking before the springs... (ball joints) and now I think its the ball joints again.
I've spoken to a lot of my friends with other cars (audis, bmws etc) and they all agree that the ball joints are the worst, especially after you lower the car.
the rubber stoppers have somethign to do with it. Plus its just so much more strain on every susp. part
I had Ground Control coilovers and Tokico blues on my Prelude, amazing ride quality and handling, but squeeky. Even friends with more expensive Tein have squeeks. i donno what it is
BIG KOUT, are you saying that replacing your stock springs (which were part of a full suspension design plan) puts strain on the suspension? Would like to know of any possible drawbacks of lowering the car (besides squeeking).
Well .. if you lower the car (springs) and don't put new shocks ... then its only fair that the stock shocks will wear out faster...
I have mine on for 1 year now on the stock shocks and its fine. and I drive 30K kms in a year... so I am putting more than avg. miles
Originally Posted by Seotaji
your stock springs came with a rubber pad that cushioned the springs so that they wouldn't make noise. try taking them off the old springs and putting them on your new ones with weatherstrip adhesive.
Originally Posted by patrick
Read my post above. You should not have squeeks if you have spring isolators installed. Just make sure you get enough of them to wrap each and every coil of your spring.
Originally Posted by thsiao
Does it squeek with ANY aftermarket spring? I am planning to get the H&R OEs... will those squeek as well?
Does that mean that your car will be squeaky if you change to an aftermarket spring?
Seotaji: get spring isolators, and you won't have any more squeaks.
cycdaniel
12-17-2019 10:58 AM
