spoon calipers
Old Oct 22, 2007 | 02:15 AM
philly fresh's Avatar
Its good to be FRESH!!
spoon calipers
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
is this something we can do on our cars. simple bolt on calipers. this is from the 6thgenaccord forum i belong to. he hasnt gotten back to me. if its that easy ill do somthing along these lines. looks hella sick
Old Oct 22, 2007 | 10:56 AM
derrick's Avatar
NeoTLS (Toronto) has had Spoon calipers on his 2ng gen TL since as long as I can remember (2001?). Not that big a deal (to me, at least).
Old Oct 22, 2007 | 11:03 AM
01tl4tl's Avatar
If looking for a good upgrade in calipers at a great price
Gen2 TLs can use 95 Legend LS Coupe 2 piston calipers
rebuilts are about 75 each- same as TL calipers
You swap them Left for Right on the install so bleeder is on top
Use TL brackets TL pads
This thing is a stopping machine now!
Old Oct 22, 2007 | 12:59 PM
Billy Sacco's Avatar
Kilos of yayo in
Are they really 1500. Thats a lot might as well get the BBK for that money or save a ton and get the legend calipers.
Old Oct 22, 2007 | 03:28 PM
S1CK TypeS's Avatar
B A N N E D
how many pistons are the spoon calipers?
Old Oct 22, 2007 | 04:23 PM
c0v3rr1d3's Avatar
i think they are 4 piston.... but like it was said above they are wicked expensive and u could get a full bbk for that price from rotora. I'm still going to go the legend caliper route. For around 200 u can get brand new 2 piston calipers, add in some slotted rotors and pads and for under 500 u can have a brand new 2 piston setup, and cheaper if u get the refurbished calipers or find some junkyard specials
Old Oct 22, 2007 | 05:35 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
nice. lol @ 3, 4
Old Oct 22, 2007 | 09:24 PM
S1CK TypeS's Avatar
B A N N E D
Mike can u help me track down a set of legend calipers?
Old Oct 22, 2007 | 09:48 PM
01tl4tl's Avatar
Kragen rebuilt rayebestos pro grade
95 Legend LS Coupe-
Use the TL brackets and TL pads
Swap the calipers left for right on install so the bleeder is on top
Old Oct 23, 2007 | 08:31 AM
snowman81's Avatar
Sippy Cup (x2)
I found the calipers on partsamerica.com for $89.99 each but it includes the pads. The only ones that I saw without the pad, also didn't have the installation bracket. Not sure if it would work without the bracket or not but those were only $62.44. There was also a core charge, so I wonder if you could swap out the calipers, make sure everything works right, then turn the TL calipers in for the core charge.
Old Oct 23, 2007 | 08:45 AM
fsttyms1's Avatar
You dont need the bracket. Buy them get charged for the core, remove yours, install new ones and return yours. Thats the way i would do it.
Old Oct 23, 2007 | 08:57 AM
snowman81's Avatar
Sippy Cup (x2)
That's what I was hoping to hear. I just wasn't sure if they would fit the TL bracket, but since it does, that makes it even easier. Thanks.
Old Oct 23, 2007 | 09:40 AM
c0v3rr1d3's Avatar
i'm talking with my parts guy at the dealership here in RI since he gives me 20% off the list price, i'm just confirming with him that the parts are brand new and not refurbished if so looking at 74 bucks a caliper plus 60 core charge. He just is not 100% sure if acura will refund the core for the tl caliper on a legend caliper but if these are new i will try it and see what happens and go from there.
Old Oct 23, 2007 | 10:02 AM
01tl4tl's Avatar
Anything that takes a CORE charge is rebuilt- why do you think they want your old ones??
kragen less likely to know the diff in returned parts- use them
Just get the raybestos pro grade rebuilts
All these things are is a tiny piston and a few orings!
Rebuilt is fine- $72 at kragen online
REMEMBER you MUST run the left caliper on right side of car and the right on left,
that puts the bleeder nipple on top
The legend bracket does not fit
TL bracket TL pads are the right item
95 legend ls coupe has closest together piston size= we want that
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
polish_pat
Sep 30, 2015 12:22 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
