spoon calipers
spoon calipers
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
is this something we can do on our cars. simple bolt on calipers. this is from the 6thgenaccord forum i belong to. he hasnt gotten back to me. if its that easy ill do somthing along these lines. looks hella sick
2.
3.
4.
5.
6.
7.
8.
9.
10.
If looking for a good upgrade in calipers at a great price
Gen2 TLs can use 95 Legend LS Coupe 2 piston calipers
rebuilts are about 75 each- same as TL calipers
You swap them Left for Right on the install so bleeder is on top
Use TL brackets TL pads
This thing is a stopping machine now!
i think they are 4 piston.... but like it was said above they are wicked expensive and u could get a full bbk for that price from rotora. I'm still going to go the legend caliper route. For around 200 u can get brand new 2 piston calipers, add in some slotted rotors and pads and for under 500 u can have a brand new 2 piston setup, and cheaper if u get the refurbished calipers or find some junkyard specials
I found the calipers on partsamerica.com for $89.99 each but it includes the pads. The only ones that I saw without the pad, also didn't have the installation bracket. Not sure if it would work without the bracket or not but those were only $62.44. There was also a core charge, so I wonder if you could swap out the calipers, make sure everything works right, then turn the TL calipers in for the core charge.
Originally Posted by S1CK TypeS
Mike can u help me track down a set of legend calipers?
Anything that takes a CORE charge is rebuilt- why do you think they want your old ones??
kragen less likely to know the diff in returned parts- use them
Just get the raybestos pro grade rebuilts
All these things are is a tiny piston and a few orings!
Rebuilt is fine- $72 at kragen online
REMEMBER you MUST run the left caliper on right side of car and the right on left,
that puts the bleeder nipple on top
The legend bracket does not fit
TL bracket TL pads are the right item
95 legend ls coupe has closest together piston size= we want that
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
