Speedo problems?
Old Nov 3, 2011 | 12:15 AM
PIC's Avatar
PIC
Rollin In The Deep
Speedo problems?
So My car has been doing this awesome thing were if you lightly step on the gas the speedo drops to 0 and then 5 or 10 seconds later shoots back up, anyone have this problem or one like it?
Old Nov 3, 2011 | 01:52 AM
my.daily'tl''s Avatar
Always Working In
Have you looked at the wheel sensors and their wiring? And at the cv axle nice and clean? Dirt, grease may throw the reading off. I would rule that out first. Never heard of the particular problem.
Old Nov 3, 2011 | 01:54 AM
PIC's Avatar
PIC
Rollin In The Deep
How would I go about checking these?
Old Nov 3, 2011 | 02:03 AM
Always Working In
Theyre located at the back of each wheel. Follow the axle. Youll see teeth at the wheel. Wheel sensors measure the rpm's at these teeth to determine speed. They also control the tcs system when they detect wheelspin.
Old Nov 3, 2011 | 02:27 AM
Always Working In
#9,10
Old Nov 3, 2011 | 02:35 AM
PIC's Avatar
PIC
Rollin In The Deep
Thanks man!
Old Nov 3, 2011 | 08:32 AM
assclown's Avatar
2000 acura tl FPR
this is all while in the driveway right?
Old Nov 3, 2011 | 08:56 AM
PIC's Avatar
PIC
Rollin In The Deep
ha...
Old Nov 3, 2011 | 12:27 PM
Rejckt's Avatar
last time i checked, we had 2 vss thats located in the tranny.
Old Nov 3, 2011 | 03:45 PM
Always Working In
Idk if theyre related to speedo.
Speedo input comes from wheel sensors. Alot of people who change wheels get incorrect info from incorrect tire/wheel size.
Old Nov 3, 2011 | 04:30 PM
TLer trash's Avatar
Rejckt has it right. Speedo gets its info from vehicle speed sensor located on trans. The vss, like the wheel speed sensors don't really know the vehicle speed, they just know how many rpms the wheels or trans output are turning. Different size tires raise or lower the rpms for any given speed, hence the error. I'm not saying that a manufacturer couldn't use wheel speed info for a speedo, [old air cooled vws ran a cable from the lf wheel] it's just that our cars don't do it.
Old Nov 3, 2011 | 07:13 PM
Rejckt's Avatar
Only 1 of the 2 sensors is known to fail, a second cause of speedo problem would be a bad ground
Old Nov 4, 2011 | 02:48 AM
Always Working In
^ I stand corrected.
Do the sensors ground to the engine/trans?
Old Nov 4, 2011 | 09:29 AM
Rejckt's Avatar
^Not sure, but nothing's grounded to the tranny. I added an additional ground from tranny to chassis.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
