Something is wrong with my tachometer
Old Jun 25, 2005 | 04:37 PM
FiftyFive's Avatar
Moderator Alumnus
My tachometer is not giving accurate readings. It will stay at a certain amount of rpms and then when i give it gas it will stay for a second then jump up to the new reading, its very jiterry, but the car is having no problems driving, and everything else seems to work just fine.
What could this be? and has this happened to anyone else?
Old Jun 25, 2005 | 04:45 PM
thAviEtbOi 37's Avatar
do you have gauges install on it? If you do that is most likely the problem
Old Jun 25, 2005 | 04:48 PM
FiftyFive's Avatar
Moderator Alumnus
all the gauges and everything are completely stock
Old Jun 25, 2005 | 06:58 PM
MY2002TLS's Avatar
Sounds to me like something is loose. maybe a cable, or the needle?
Old Jun 25, 2005 | 10:20 PM
sbuswell's Avatar
I need 2 more gears
maybe it's just v-tec kickin in cause it jumps real fast when you engage v-tec. I have a 99 and when I hit v-tec it goes from 3800 to 5000 very quickly, but I have headers and K&n filter so that might help it get up there quicker, but still. Does it just stick at like 3000 and then shoot up to 5500+? More detail would help.
Old Jun 26, 2005 | 12:57 PM
FiftyFive's Avatar
Moderator Alumnus
nice try though
FiftyFive's Avatar
Moderator Alumnus
the tachometer is just very jitery and jumps from lets say 1000 to 2000, then 3000 to 4000, and same way back down
Old Jun 26, 2005 | 05:47 PM
unlemming's Avatar
Smitty's Moral Police
Sounds like a tranny failure to me..
Old Jun 26, 2005 | 06:46 PM
FiftyFive's Avatar
Moderator Alumnus
update - it stopped doing it, am i in the clear, or what should i do?
Old Jun 26, 2005 | 10:01 PM
Pure Adrenaline's Avatar
Dragging knees in
It's most likely just a gauge problem. Worst case scenario, your crankshaft position sensor is going bye-bye.
Old Jun 27, 2005 | 06:05 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
Does anyone know where to get a digital tach/odo reader that you can just tap into the speed sensor wire?
Old Jun 27, 2005 | 06:27 PM
Dragging knees in
The closest thing I can think of is the Apex'i RSM, but as far as I know, it is not compatible with UA4/UA5.
Old Jul 3, 2005 | 11:33 AM
heehaaw's Avatar
loose cable. get it checked. should be simple.
Old Jul 3, 2005 | 12:00 PM
fla-tls's Avatar
On the way!
Could be a sensor going out as well. Go to Auto Zone and get a free scan. Some codes don't light up the check engine light.
Old Jul 3, 2005 | 07:49 PM
brakejob's Avatar
:brakejob:
vtec hits at 4500 in a tl-p afaik
also, it is vtec not v-tec
acuratl26
Apr 23, 2020 07:30 PM
ttimberlak443
21
Oct 22, 2016 10:23 PM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
rangomango
California
Sep 24, 2015 05:47 PM
Hines57
Sep 24, 2015 01:58 PM
