Is this something to be concerned about?
Old Sep 25, 2012 | 09:56 PM
1st timer's Avatar
UB6IB9
I never notice any stains on my driveway but today as I was doing an oil change, I noticed something is leaking,but from where?
There doesn't seem to be any fresh oil anywhere and i never notice anything on my driveway. What do you guys suggest? Btw, I changed the rear main seal 2 years ago.
Old Sep 26, 2012 | 12:00 AM
closetprisoner's Avatar
2000 Acura TL
Looks better than mine.. I wouldn't worry about it
Old Sep 26, 2012 | 12:05 AM
Skirmich's Avatar
If you dont know from where did come out then probably is puked ATF from the trans Breather tube...
Old Sep 26, 2012 | 02:09 AM
01tl4tl's Avatar
remove the inspection cover under trans/engine connection--2 small bolts
if engine oil in there its rear main seal
BUT
we have found clogged PCV $10, forcing pressure and oil past the rear main seal!!
replacement solved leak
if its a really odd fluid ck the motor mounts, front and rear
Old Sep 26, 2012 | 06:47 AM
1st timer's Avatar
UB6IB9
what would cause that?
Old Sep 26, 2012 | 08:55 AM
fsttyms1's Avatar
That could be old oil from the rear main or you may have a new rear main leak. It also could be from a valve cover. Clean it up and drive it a month and see if it shows back up.
Old Sep 26, 2012 | 10:39 AM
acutee's Avatar
It is a sign of leaking if you didn't see it before. Do as said above to inspect where the leak comes from.
Old Sep 26, 2012 | 10:48 AM
01tl4tl's Avatar
remove that cover, wipe it dry inside if needed,,drive and monitor
ck PCV valve,,may as well replace it based on age, under 10 bucks- any parts store
back in the day we changed these every year!
stogie1020
Cameras & Photography
17
Sep 30, 2015 01:34 AM
mars
Sep 28, 2015 11:03 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
spoiler900
Sep 23, 2015 04:41 PM
