Some engine vibration at idle
Old Jan 29, 2006 | 04:47 PM
zibadun's Avatar
Is it normal to feel slight vibration in the seat when the car is idle on park? The vibration is low beat frequency (less than idle rpm) and has irregular pattern. It's not severe but I can definitely tell the engine is running (I have 02 tls). The reason I ask is becuase in my previous car v6 accord I could not really feel the engine idling, so I just want to make this is not something to be alarmed about. thanks
Old Jan 29, 2006 | 11:06 PM
khoifl's Avatar
How miles do you have on the car? Well, I have 52K on 02 TL-P, and I feel a bit when it's at D5 and I'm holding the brake.
Old Jan 30, 2006 | 09:16 AM
zibadun's Avatar
mine is also at 52k
Old Jan 30, 2006 | 02:18 PM
acurabum's Avatar
What is your RPM when idling ? It's drop to 650 rpm or stay at 750 rpm when
your car vibrate ?
Old Jan 30, 2006 | 07:32 PM
MrAlex's Avatar
99 SSM Tl
umm is your motor mount ok ?
Old Jan 30, 2006 | 09:48 PM
khoifl's Avatar
I replaced mine under original warranty.
Old Jan 30, 2006 | 09:56 PM
DLCU2's Avatar
mine is @ 72k...it only happens sometimes. engine would vibrate a little and the rpm would jump around a bit (this only happens after i drive around a bit around the block. is it the transmission?..maybe im shifting between the 2nd and 3rd gear too much?
Old Jan 30, 2006 | 10:13 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
I don't notice any vibes in my 02 TL-P @ 55k miles... until I get to about 75-80mph
Old Jan 31, 2006 | 08:09 AM
zibadun's Avatar
your car vibrate ?
I think idle stays closer to 900 but I will play close attention. What if the idle drops is it sign of a bigger issue?
is there an easy way to check check this?
thanks
Old Jan 31, 2006 | 02:10 PM
khoifl's Avatar
Did you balance your tire? Or get softer wall tires.
Old Jan 31, 2006 | 02:13 PM
acurabum's Avatar
The right RPM at idle is 750 if it drops a bit while vibrating then you might have
a problem with the idling valve control .
Clean the TBody first , check your air filter.. before jumping to any conclusion.
Good luck
Old Jan 31, 2006 | 02:22 PM
VoLLy's Avatar
Meridian
I get the same vibration on idle as well.
Old Jan 31, 2006 | 05:51 PM
03CoupeV6's Avatar
Car has OEM Michelins and repeated balances and new sets of tires and new motor mounts haven't solved it. But this is not appropriate for this thread.. it belongs to someone else.
Old Feb 3, 2006 | 10:09 PM
TL83s's Avatar
03 ABP TL-S
Hopefully you are still under warranty if so have Acura service check your motor mounts my front and left motor mount was cracked causing vibration at idle.....
Old Feb 4, 2006 | 06:56 AM
gemineye's Avatar
3rd Gear
ditto
I have a 02 TL-S and it idles irregularly most times.
Not sure why, though.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
IlliniAcura
Sep 19, 2015 09:31 PM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
Mike Bertram
Sep 10, 2015 09:27 AM
