Some engine vibration at idle
Is it normal to feel slight vibration in the seat when the car is idle on park? The vibration is low beat frequency (less than idle rpm) and has irregular pattern. It's not severe but I can definitely tell the engine is running (I have 02 tls). The reason I ask is becuase in my previous car v6 accord I could not really feel the engine idling, so I just want to make this is not something to be alarmed about. thanks
mine is @ 72k...it only happens sometimes. engine would vibrate a little and the rpm would jump around a bit (this only happens after i drive around a bit around the block. is it the transmission?..maybe im shifting between the 2nd and 3rd gear too much?
Originally Posted by acurabum
What is your RPM when idling ? It's drop to 650 rpm or stay at 750 rpm when
your car vibrate ?
your car vibrate ?
Originally Posted by MrAlex
umm is your motor mount ok ?
thanks
Originally Posted by 03CoupeV6
I don't notice any vibes in my 02 TL-P @ 55k miles... until I get to about 75-80mph
I think idle stays closer to 900 but I will play close attention. What if the idle drops is it sign of a bigger issue?
a problem with the idling valve control .
Clean the TBody first , check your air filter.. before jumping to any conclusion.
Good luck
05 C230K & 09 135i 6MT
Originally Posted by khoifl
Did you balance your tire? Or get softer wall tires.
03 ABP TL-S
Hopefully you are still under warranty if so have Acura service check your motor mounts my front and left motor mount was cracked causing vibration at idle.....
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
Mike Bertram
09-10-2015 09:27 AM
