Side mirror auto tilt down in reverse
Old Mar 13, 2002 | 09:18 AM
randomwalk101's Avatar
When you put the car in reverse, the side view mirror (passenger) automatically tilts down...however, the driver side doesn't do anything (at least on mine 2002 TL)...is this supposed to be the way it is (driver side not tilting down) or would I need to make a trip to the dealer to fix it?? Thanks for the clarification.
Old Mar 13, 2002 | 09:23 AM
i'm sorry..i found the answer...no, only the passenger side tilts on reverse...thx.
fahoumh's Avatar
Shogun Assassin
Only the passenger side mirror tilts down.
Old Mar 13, 2002 | 09:27 AM
bloo_tls02's Avatar
RIF- Reading Is Fundamental.......buhahahaha
Old Mar 13, 2002 | 09:31 AM
Pawel's Avatar
Do 2000 TL does it too?
Old Mar 13, 2002 | 09:34 AM
bloo_tls02's Avatar
Dont think so, if you did there would be a button for it by the side mirror adjustment knob.
Old Mar 13, 2002 | 09:54 AM
Someone brought this up earlier and wanted to know of a mod to do this to their '00 TL...I guess if you wanted to, you could go to the dealer and get the parts needed from an '02 model and install them. Any thoughts on this actually being feasible?
Old Mar 13, 2002 | 11:08 AM
NSXNEXT's Avatar
Not possible without a bunch of money. The logic that makes it tilt down isn't in the mirror motor, it's in the main brain in the car. So you'd have to replace the main brain. Already tried to do it.
Old Mar 13, 2002 | 05:41 PM
asif2002's Avatar
yup that was me earlier. Not worth it. I would rather have a lil camera on the navi instead. :wow:
Old Mar 13, 2002 | 10:39 PM
Logic
Guest
Posts: n/a
Yes, it is only the passenger side. It's because you can see how close things are to you on the driver side for the most part (plus you need to be able to look at one of the mirrors to see what's directly behind you).
Also, make sure your mirror-select switch is set to the middle (not L or R) or it won't work. I'm not exactly sure why but it took me a while to figure out why my mirror wasn't tilting and this was the problem.
rockyboy
Aug 4, 2024 10:35 AM
space_boy
ILX
51
Aug 15, 2017 12:06 PM
sockr1
Oct 1, 2015 01:31 AM
PortlandRL
Sep 14, 2015 12:01 PM
hand123
Sep 10, 2015 09:27 AM
