Side mirror auto tilt down in reverse
When you put the car in reverse, the side view mirror (passenger) automatically tilts down...however, the driver side doesn't do anything (at least on mine 2002 TL)...is this supposed to be the way it is (driver side not tilting down) or would I need to make a trip to the dealer to fix it?? Thanks for the clarification.
Someone brought this up earlier and wanted to know of a mod to do this to their '00 TL...I guess if you wanted to, you could go to the dealer and get the parts needed from an '02 model and install them. Any thoughts on this actually being feasible?
Received 1,080 Likes
Guest
Posts: n/a
Yes, it is only the passenger side. It's because you can see how close things are to you on the driver side for the most part (plus you need to be able to look at one of the mirrors to see what's directly behind you).
Also, make sure your mirror-select switch is set to the middle (not L or R) or it won't work. I'm not exactly sure why but it took me a while to figure out why my mirror wasn't tilting and this was the problem.
rockyboy
12-06-2022 02:29 PM
sockr1
10-01-2015 01:31 AM
