SHORT Ram INTAKE problem
Old Apr 28, 2007 | 03:48 PM
vtechtl's Avatar
8th Gear
I have a problem with installing the short ram intake on my 99 tl. When i was taking out the stock intake and filter i found two tubes coming from the bottom of the intake and when i pulled it out there is i think radiator fluid coming out of the tubes. What do i do with the two tubes if i install a short ram intake? i think one is receive and one is going out.
Old Apr 28, 2007 | 03:54 PM
orgnlprankster7's Avatar
08 Civic SI
connect them together. they are for the stock intake, it has a mini radiator to keep the air warm in the cold. not needed for the shortram. connect them together and ull be set
Old Apr 28, 2007 | 03:58 PM
vtechtl's Avatar
8th Gear
just connect them ? like 0-> <-0 that ? haha i dont think the two tubes are made for connect together, you have any suggestions ?
Old Apr 28, 2007 | 04:01 PM
08 Civic SI
lets call them A and B. find where A is coming from and disconeet it completely so the hose is nolonger connected to anything, then take B and connect it to where A used to be coming from. sorry its hard to explain, but it will juts make a loop back into the engine. just look and ull see ull figure it out.
Old Apr 28, 2007 | 04:25 PM
vtechtl's Avatar
8th Gear
oh ok gotcha...disconnect a completely from the whole engine and take b and connect it to wehre a is connect to the engine...=D thanks
Old Apr 28, 2007 | 04:33 PM
08 Civic SI
yup that way it just loops back, make sure u double check that ur pluggin into the right spot so u dont get coolant where it shouldnt be
cycdaniel
Dec 17, 2019 10:58 AM
Kevin Sami
Sep 22, 2015 09:59 AM
carz0159
Sep 20, 2015 06:11 PM
Abe_Froman
Sep 16, 2015 01:27 PM
