shocks
Old Jan 24, 2003 | 03:48 AM
bobatimez's Avatar
shocks
ive been using stock shocks with eibach springs for nearly 3 yrs. the stock ones give an ok ride and i totally forgot about about needing to change the shocks. anyway, do i NEED to buy new shocks and if so, would it be possible for me to soften the ride over what its like now? which ones would i need to get. please, educate me on this issue.
thankx
Old Jan 24, 2003 | 04:06 AM
KidD WiTh 2k TL's Avatar
i have ground control coilovers on my old accord and its been like over 3 years and till this day its not bad of a ride
on my tl . . . i only had my springs for half a year and my shocks went out couple months after the installation . . . it just depends on the height of your drop i guess . . . my tl has drop pass 3 inch
Old Jan 25, 2003 | 12:32 AM
bobatimez's Avatar
please any more help?
Old Jan 25, 2003 | 01:24 AM
Allout's Avatar
Blown is Best
Since the Eibach's give you a drop of 2.1 which is on the higher side, you've lost that much wheel travel before you bottom out. The Eibach's are also progressive springs so they stiffen up real quick in a short range. If you want to keep the look and are trying to get a softer ride, you may want to get some adjustable struts (like Tokico or Koni) so you can play with the firmness.
Old Jan 25, 2003 | 03:59 AM
bobatimez's Avatar
the $280 set of tokico shocks won't do that will it? i would have to get the other ones right?
Old Jan 25, 2003 | 01:06 PM
Allout's Avatar
Blown is Best
The Tokico Illuminas are 5 way adjustables. That's what I'm running - currently on 3. I'm probably goining to try 2 on the rear this weekend. 1 is the softest.
IIDXholic
3G RLX (2013+)
23
Oct 19, 2015 09:40 PM
StevieB1503
ILX
Oct 8, 2015 04:52 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
4drviper
Sep 23, 2015 07:42 PM
