Shift Plate Backlight
Old Nov 14, 2004 | 02:23 AM
pgolfco's Avatar
Is the shift plate in a 99 TL supposed to be backlit? If so, how is it replaced and what type of bulb is used? Thanks..........
Old Nov 14, 2004 | 11:58 AM
sc354's Avatar
Are you referring to where the gear shifter is??? My P, R, N, D5, D4, D3, D2<>1 all light up...so if that's what you're referring too, then yes there definitely should be a light illuminated behind it.
As for what type of bulb, that I have no idea...
Old Nov 14, 2004 | 01:03 PM
fsttyms1's Avatar
if you unscrew your shifter knob (turn hard counterclockwuse) then pop the plastic trim ring off around the light grey gate part,then pop the gate plate off (all just snap on off) you will then be able to pull straight up on the little cover with the selector #s on it. you will then have access to the bulb
Old Nov 14, 2004 | 03:28 PM
pgolfco's Avatar
Thanks for the responses!
Old Nov 14, 2004 | 05:07 PM
fsttyms1's Avatar
no prob
Old Nov 15, 2004 | 09:22 AM
jt24yo's Avatar
Mobile on demand Agent
thanks guys, I got the same problem, now I know how to fix it.
Old Nov 15, 2004 | 02:05 PM
slikz's Avatar
1999 Acura 3.2 TL
my P R N etc doesn`t light up =( but one night i turned on the seat heater and i looked down i saw red and green, it looked so pretty. then it finally came to me that the lights on the shifter that never illuminated is now illuminated. and when i got home it went off again -____- and i found a way to have it go back on, i have to hit it -_________- ;; so it comes on sometimes, or when i hit it, so i`m guessing the bulbs are fine. what is the problem here now? loose wiring?
Old Nov 15, 2004 | 02:33 PM
fsttyms1's Avatar
sounds like a bad or loose bulb or a bad/dirty conection on the bilb. pull it apart like i have listed above and check the bulb
Old Nov 16, 2004 | 12:40 AM
slikz's Avatar
1999 Acura 3.2 TL
okay, going to do that when i have time, thanks for the instructions.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
Popee
Dec 20, 2015 12:08 AM
Hines57
Sep 24, 2015 01:58 PM
