Shaking/vibrating problems
Old Aug 25, 2005 | 02:07 PM
lately, when i'm braking at high speed (60mph or greater), my steering wheel would shake back and forth alot, and i can feel the car vibrate. i was just wondering what is causing this? is it alignment, wheel balance, or rotor/brake problems? a friend had mentioned that it is probably the rotor. any feedback is appreciated. thanks!!
i have a 03 tl type-s, with about 30K miles on it. i'm still on the original stock tires, so the tires are almost worn out (looking to replace it soon)
Old Aug 25, 2005 | 02:14 PM
Blazin_TL's Avatar
Registered User
warped rotors..
Old Aug 25, 2005 | 02:46 PM
DzTL-S's Avatar
^^^ I agree
Old Aug 25, 2005 | 03:20 PM
fsttyms1's Avatar
warped rotors Very comon on the TL
Old Aug 25, 2005 | 03:54 PM
thanks guy for the quick replies. so i guess that mean i need to get new ones!! is that the average wear time for rotors ~ 25K - 30K miles? would you recommend getting OEM rotors or aftermarket rotors?
Old Aug 25, 2005 | 04:00 PM
bumski667's Avatar
NBP
i need to replace mine too
too bad i don't have the money for the rotora bbk kit
Old Aug 25, 2005 | 04:01 PM
acutee's Avatar
Take it to the dealer, and they will resurface the front rotors for you. or just get new after market rotors and new pads. Stock rotors are known to fail prematurely.
Old Aug 25, 2005 | 04:03 PM
VoLLy's Avatar
Meridian
i had that problem too, but when i took it to the shop, they said the rotors did not have to be replaced, instead they just resurfaced them. after that, it was less shakey for me. you can still feel a little but not as much as before.
Old Aug 25, 2005 | 06:01 PM
Mike_McCready's Avatar
I got mine resurface and they are as good as new. They have been good for 5k miles now. I figure the next time they warp on me I'll upgrade to irotors or something
oh and if you go aftermarket, get slotted. They help alot, and drilled tend to crack if you don't get high quality ones
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
