Seat Rails
Mr. 2tone
Seat Rails
im plan is to get replace the front 2 seats with bucketseats...but in order for me to do that i need manual seat rails...does any1 know if the accord seat rails fit in the tl? kuz its the same chassis n all so wouldnt it b the same? if it doesnt...does any1 know where i can get them on the net? there was some1 on here that was selling seat rails but i think that thread was daaaays ago n i didnt find it when i searched...thx a bunch
i really wouldnt suggest that. usually with a harness is suppose to be used with a roll cage, to prevent your head from getting crushed. but anyways, IF you were to get it mounted, the harness is to be mounted at a certain angle. if the angle is too much it may not work properly.
05 C230K & 09 135i 6MT
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
To put this in simple terms - no matter what you do, if that red "SRS" light is on - the airbags and seatbelt pretensioners WILL NOT FUNCTION.
Future JDM Whore
Originally Posted by Leviathan
Unless they are leather, they are gonna look rice IMO.
I wouldn't do it just because of the airbag situation anyways.
If he follows through with this modification, it's probably going to be more work than he bargained for. The side airbags will be gone, and who knows how he'll trick the SRS system into thinking they are there. And the OPDS light (Side Airbag Off) will probably go nuts. If he leaves the SRS light on, crash protection is greatly reduced - the airbags and electronic seatbelt tensioners will not function.
your life or the so called "jdm" look as stated above? your choice.
Acura TLS are SLOW
The accord seat brackets will fit but you have have to modify one of the mounting bolt on the rear of the bracket. As for the SRS, a resister has to be used to to turn the SRS light off and keep the rest of the system working (ie front airbags).
Acura TLS are SLOW
Originally Posted by fsttyms1
I was going to say something like that. There has to be a fairly easy way since i know hes not teh only one who has done something like this.
yea yea yea....i just beat you to it
I would go check to see what type of resister is needed but im too lazy. If you want take a Muilti meter and play around with the 2 green SRS line and see what ohms you need to slow the current flow down.
Originally Posted by z3Ro
from what i heard it can b bolted down to anywhere...(i.e. which means u can bolt it down under the rail) thats where i was thinking bout
Mr. 2tone
yea...safety is 1st...n i do know the place that can help me trick the SRS...as for the mounting the harness...i dont know where else...kuz i still want passengers in the rear...thx for all the lil details every1...
運転することを愛
I say do what you want to do. Yet I don't quite get this one. The TL isn't a lil sport compact, nor is it a sports car for which racing seats with 5 pt.'s would be fitting. I think the type-s seats fit the car just fine, staying in tune with the luxury aura of Acura.
Mr. 2tone
cls seats were my 1st pick...but thats more $$...the direction im going with the car is its primarily a track car n secondly a mild show car...everything but supercharger under the hood n a suspension setup for track use n no ICE at all...the main reason i need buckets is kuz the suspension is so stiff that im get lifted up from my seat everytime i drive around...n thats where the harness come in...
運転することを愛
I gotcha. My suspension was extremely stiff on my last car and it gets really annoying when you bounce and slide all over the place. Best of luck on making something work. You will need a resistor in order to keep the SRS light off and keep the airbags functioning. Let me know what you find though, I'm curious to see what is required.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
