scratch remover?
Old Nov 27, 2001 | 11:21 AM
TypeSDragon's Avatar
Loving my 08 TLS!
Question scratch remover?
I have a minor scratch on the hood while waxing my car. Is there a scratch remover that will take care of this problem? I tried a scratch remover forgot what brand and it didn't do sh*t! If anyone knows of a good one, please let me know. Thanks!
Old Nov 27, 2001 | 11:24 AM
fahoumh's Avatar
Shogun Assassin
if it's a fine scratch, maybe Z5 can take care of it?
Old Nov 27, 2001 | 11:25 AM
NSXNEXT's Avatar
Meguiars Scratch-X or Eagle One Scratch Remover are both very good. I recommend Scratch-X
Old Nov 27, 2001 | 11:37 AM
Sal Zaino recommend a foam from 3M for scratches that z5 wouldn't remove.
Old Nov 27, 2001 | 08:21 PM
Recently, I posted a message about this caus I got a long scratch on the side of my car.
If by scratch, you mean other car's paint on yours, that is what I had. A black Eagle Talon left a long side mark on my car.
Solution : I tried Paint solvant, scratch remover product, and none of these seems to take the paint scratch off.
Here I come, the solution : Take hot water and scratch the mark off with your finger nails. The paint has to be warmed up first, and scratch gentlely. It takes time, but it works.
Now, if your scratch has gone deep in the car's paint, it is another problem.
Tell me if it works...
Later.
Old Nov 28, 2001 | 06:26 PM
Austin519's Avatar
Davidas:
"Recently, I posted a message about this caus I got a long scratch on the side of my car.
Later."
No offense but that's an awful idea man. If you scratch it off with your fingernails you get messed up fingernails, and you may scratch your own paint. Why not use hot water, soap, and a clay bar instead? That's the way to go about it.
Austin519
Old Nov 29, 2001 | 03:50 AM
typeSmaximum's Avatar
I also I recommend Scratch-X
Old Nov 29, 2001 | 09:06 AM
Loving my 08 TLS!
Where can I buy Scratch-X?? I went to Pepboys last night, but they don't have crap. I need to get rid of that scratch ASAP. It is really bugging me...
Old Nov 29, 2001 | 11:04 AM
systek's Avatar
Austin519
is that what a clay bar is for??? ive never asked cuase i didnt want to look the fool...jajaja
anyway. im back from my trip to chicago, it was awesome, car gave me nooooooooo probs and not a scratch on it, which worried me cause of the extensive valet service we (ab)used...!
Old Nov 29, 2001 | 02:02 PM
Austin519's Avatar
systek:
Good to see you back bud
"is that what a clay bar is for??? ive never asked cuase i didnt want to look the fool...jajaja "
Yep sure is. Actually what you normally use it for is to remove contaminants from paint to keep it from deteriorating and to prepare it for wax (removes all waxes etc). But paint is a contaminant...in fact I've heard of a lot of Body shops charging $300, taking the car to the back, then rubbing it with a Claybar and giving it back...
Austin519
Old Nov 29, 2001 | 02:35 PM
Austin519 [/B]
Well, it worked for me!! It will work if you don't have female fingernails....if you see what i mean...
Old Nov 29, 2001 | 03:21 PM
systek's Avatar
jajajajajajaja
Old Nov 29, 2001 | 04:57 PM
WalkThisWay's Avatar
I have used about a half dozen different "scratch removers" over the years. Most were a waste of money.
The one that does the "Best Job" on the very soft and easily damaged TLS paint is Mequires Scratch X. That includes the soft plastic bumbers too!
Good Luck
Old Nov 29, 2001 | 05:02 PM
Austin519's Avatar
Davidas:
Heh heh... You callin me a woman, son? Ima callin you out son! DRAW!!!
Austin519
Old Dec 2, 2001 | 06:14 PM
ChucksCL-S's Avatar
Deep scratches into the paint color are another matter but most light scatches are in the clearcoat which is the last coat of course. This is good as they can be repaired pretty much. Light damage can be fixed by rubbing or carefully buffing with Meguires Swirl Remover. If the scratch is still visable it's deeper into the clearcoat so some clear has to be removed - but don't freak as there is plenty of it for light repair purposes. Get some Meguires Fine Cut Cleaner and rub the scratch by hand - yes it will haze the clearcoat but when you follow that step with your swirl remover ( and then wax ) you should be back to perfect. The only caution is that over use of any product that "cuts" could go into the color coat which is FLAT paint, not glossy making things worse. Buffers are time savers but you don't want to leave them running on one spot as they'll overheat your finish and leave a burn mark. I've been doing it this way for ten years with an 80% sucess rate I guess. Using the Meguires numbering system Swirl Remover is #9 and Fine Cut Cleaner is #2. Hope this helps!
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
datadr
Mar 23, 2016 01:39 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
