Reverse sound
Old May 25, 2003 | 03:48 PM
bubbaTL2000's Avatar
Reverse sound
Has anyone ever had this problem:
Everytime I put the car in reverse lately a continuous beeping sound goes off, the same sound I hear when I reverse the car and if Im close to another car or object a beeping sound goes off. However, now it goes off everytime I put it in reverse whether or not if im near a another car or object.
Old May 25, 2003 | 04:29 PM
Iggy's Avatar
I did'nt know the 2000TL had reverse proximity sensors. I wish mine did.
Old May 25, 2003 | 04:55 PM
Raheel's Avatar
LOL
Old May 25, 2003 | 06:02 PM
Comet2404's Avatar
Flyin' and Drivin'
I'm confused...
Old May 25, 2003 | 09:21 PM
Raheel's Avatar
Originally posted by Comet2404
I'm confused...
isn't everyone?
Old May 25, 2003 | 09:28 PM
SilverUA5's Avatar
Re: Reverse sound
what the hell are you talking about?
Old May 26, 2003 | 12:20 AM
Raheel's Avatar
Re: Re: Reverse sound
Old May 26, 2003 | 03:04 AM
VTEC's Avatar
Did you put aftermarket reverse sensors??
Or is it something is hidden feature??
Old May 26, 2003 | 07:28 AM
ArN 2000 TL's Avatar
Moderator Alumnus
Did you buy the car used or brand new from the dealer?
Old May 27, 2003 | 10:51 AM
proximity sensors
I bought the car used from a dealer and didn't even know the car had this feature.
Old May 27, 2003 | 11:41 AM
Iggy's Avatar
Ok, now that we that hashed out I have a couple of suggestions.
Is it raining of foggy out when you have this problem. If so it could be that moisture is on the lenses of the sensors, wipe them down and see if it helps. Also, see if you can tell if there is moisture on the inside of the sensors. Anything blocking the lenses will make the ultrasound transceiver think that there is something REALLY close, when in fact it just can't see beyond them. At least that's what i've learned with the system on my Explorer.
Cheers,
Iggy
Old May 27, 2003 | 01:37 PM
Raheel's Avatar
HAHA This is funny and freaky..
Buying a car that is doing wierd shiat
Old May 27, 2003 | 05:14 PM
fla-tls's Avatar
On the way!
Are you sure you weren't driving a Ryder rental truck?
Old May 27, 2003 | 10:39 PM
Raheel's Avatar
I was just wondering if it could have been a garbage truck that makes that beep beep sound when you go in reverse
Old May 29, 2003 | 08:25 AM
sc354's Avatar
Re: Reverse sound
I had the exact same problem on my TL. I had some weird noise coming from the back end of the car when put in reverse, but as soon as I put into drive, and move forward, the sound would go away.
I brought it to the dealer and it turns out, that noise is a sensor for the rear brakes. When the pads begin to get thin, the piece of metal rubs the rotor creating a weird noise. It's basically a sensor to tell you the rear brakes need replacing. Just bring the car in, and have them check the rear brakes.
That's all it should be.
blacktsxwagon
Oct 27, 2015 10:12 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
TL14
Sep 24, 2015 04:37 PM
STC
Sep 23, 2015 04:36 PM
