restarting problem!!!
Old Oct 8, 2004 | 12:07 PM
bkzjimmy's Avatar
NiGhT rIdEr
does anyone else have this problem??....after driving for a while i would shut off my car then wait a few minutes then when i start it back up it feel like its about to stall...help me with this one...its annoying!
Old Oct 8, 2004 | 12:14 PM
99TLHeather's Avatar
That happened to me for about a month, and my start wasn't as quik as it used to be. My battery was dying. Check to see if your battery still has any life left. A mechanic shop could check for you. I had my battery checked and was told that it needs to be replaced. I ordered red top optima.
Old Oct 8, 2004 | 12:18 PM
aw1's Avatar
aw1
Had this same problem with my 2000 Honda Accord Cpe EXV6. The intial start is fine until you drive out and park your car for several minutes or more. At the second start up, the car will start, but then the rpm will drop below 600. At this time, the car will start shaking and vibrating. This is cause by the regulator or whatever they call it that controls the RPM and keeps it at 600 so the car wont stall or die. Honda had to replace this part for me which cost 3-4k, but luckily my car was under warranty. The part had to be shipped from Japan cause they didnt have this part here. The funny thing is that the service guy said that they (Honda) knew about this problem and my car falls in the range of vin #' with this problem. Good Luck with getting this fixed.
Old Oct 8, 2004 | 12:38 PM
bkzjimmy's Avatar
NiGhT rIdEr
shit...i dont know if that under warranty cause mine is a 2000 with 43000k miles....i have a new battery so i dont think thats the problem..i dont feel like paying 3-4k on that shit
Old Oct 8, 2004 | 02:01 PM
thumpy's Avatar
If your starting problem only occurs after the car has been running and is hot ... .... There is a service bulletin for this problem, if your car is under warranty get in fixed now. The cost to get this done is $1000.00 plus. Its a fuel delivery problem, the additives in the fuel during the winter months cause a vapor lock or something. You'll notice it doesnt happen during the summer.
I refuse to fix the problem, the dealer quoted me $1600.00 Canadian Dollars... MF pricks I feel like smashing someones skull when I think about this and the fact the dealer or ACURA wont fix the F'n problem..
Old Oct 8, 2004 | 02:22 PM
aw1's Avatar
aw1
Thumpy, I feel your pain.. If I had to cough up the money out of my own pockets, I would not have this fixed either.. Also, the problem was not just in the winter time, it was also in the spring, summer and fall...
Old Oct 11, 2004 | 02:09 PM
Faizalstar's Avatar
TLStar
you don't say?? I just changed my battery 2 days ago cuz it was time for a new one. now, my initial start is fine but after trying to start again within a few hours and it starts to sound like it's gonna die! SOaB. Another friggin Acura problem!! Should stayed with my Civic!!!
Old Oct 13, 2004 | 06:36 PM
bkzjimmy's Avatar
NiGhT rIdEr
is this a problem that only acura can fix or any mechanic?.....i have a 2000, im not sure its still under waranty even tho i only have 43000 miles.....i wanna drive right into a wall...cauze today after i tried to start it back up again, it stalled like 3 times, so then i started it up and threw it right into driveand hit the gas...the car was jumping really bad, but i kept hitting the gas and it stops jumping...f#cking car!
Old Oct 14, 2004 | 09:46 AM
aw1's Avatar
aw1
any mechanic can fix this if they know what they are looking for. best bet is to bring it back to acura and see what they say. they will plug your car into the computer and run a test to find the problem. honda did not find the problem until the 2nd time i bought my car to them. good luck.
Old Oct 14, 2004 | 07:38 PM
Team Nighthawk Member
could be your ignition switch. i had the same problem i have a 99 tlp and it was under a recall order b./c of faulty switches. get it looked at.
Old Oct 15, 2004 | 09:08 AM
bkzjimmy's Avatar
NiGhT rIdEr
i just filled up my tank it put in some fuel cleaner......the problem stopped!
SidhuSaaB
May 30, 2020 12:40 AM
Puma Jim
20
Oct 20, 2016 11:59 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
