Resonator removal????
Old Apr 29, 2003 | 08:41 AM
cantl88's Avatar
@(UR@ +!
Hi guys,
Just wondering what advantages I would have if I were to remove the resonator.
Are their any negative side effects?
And finally how would I go about removing it?
Thanx for the help in advance
Old Apr 29, 2003 | 09:21 AM
Tatewaki's Avatar
Advantage:
- air flows slightly better to the engine
- sounds better
- cheaper than CAI/icebox
- Add a pipe from filter box to bumper for your own icebox
Disadvantage:
- air filter may get dirty quicker
How:
- Remove front bumper
- Remove resonator
(simple enough? )
Old Apr 29, 2003 | 09:56 AM
cantl88's Avatar
@(UR@ +!
Thanx Tatewaki...
Are there any hp gains at all from removing it? Any better throttle response or anything besides sound?
Old Apr 29, 2003 | 10:22 AM
neotls's Avatar
Slap on a K&N air filter and the car will feel more responsive when accelerating plus 1 to 2 HP
Old Apr 29, 2003 | 10:23 AM
Tatewaki's Avatar
hp gain is close to nothing. Don't expect any.
Throttle response is better, but I also have a K&N in there after I removed it
This is mainly for sound, it doesn't do much otherwise
Old Apr 29, 2003 | 01:29 PM
cantl88's Avatar
@(UR@ +!
When you guys are talking about the K&N filter I'm assuming that you're talking just about the drop-in replacement filter and not a CAI or short-ram intake right?
Old Apr 29, 2003 | 03:50 PM
Tatewaki's Avatar
Just K&N drop in...However, once the resonator is removed, you can use your imagination and fit a cone filter under the air bos
Old Apr 29, 2003 | 04:02 PM
fsttyms1's Avatar
i took out the resonator put a k&n drop in in and cut the bottom out of the air box (the hole where the CAI goes through is right under it now feeding more of the cold air to the filter. sounds good too
Old Apr 29, 2003 | 08:40 PM
Darkshear's Avatar
l33t
yah after removing the resonator in mine, it sounds a little better, but not as good as if i did full intake...
Old Apr 29, 2003 | 10:41 PM
which part of the engine is the resonator?? and what does the resonator do? any pics of it
and also, I don't understand the part about cutting out the buttom of the air box. is the resonator aka the air box? thanks for the help
Old Apr 30, 2003 | 08:59 AM
fsttyms1's Avatar
if you take out your air filter and air filter box and look down thats where your resonator is. to get at it you have to either take the front bumper cover off(easy) or do it from the wheel well and from underneath the car by removing some of the plasti guards
Old Apr 30, 2003 | 04:51 PM
Comet2404's Avatar
Flyin' and Drivin'
I had to take out the resonator from my car to install the CAI... and I'm just going to say one thing.... PAIN IN THE ASS!
Old May 1, 2003 | 10:33 AM
What does it do?.. what is the purpose for a resonator?
Old May 5, 2003 | 06:47 PM
TL-S Man's Avatar
It quiets intake noise--removing it allows for freer airflow to the filter and more engine noise at wide open throttle.
Old May 5, 2003 | 08:44 PM
WWW
Papa Bear
In the second picture from the top, you can see the resonator. It's the black "box" on the driver side right behind the bumper.
http://www.techwhiz.org/auto/cai.htm
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
eastsideride
Oct 15, 2015 04:26 AM
merc009
Sep 29, 2015 03:06 PM
Rcelestino93
Sep 23, 2015 10:01 PM
