Resetting Maint. Reqd. Light?
Old Jun 27, 2004 | 01:30 PM
evercn1's Avatar
How is it that you do that?
Old Jun 27, 2004 | 01:52 PM
MadisonTLS's Avatar
With car off.
Reach thru the steering wheel with your left hand and press and hold both the buttons on the dash (reset and a/b?).
Turn the key so the power comes on but not the engine.
Hold for 10 secs.
I think that's it.
Old Jun 27, 2004 | 04:45 PM
954Rocks's Avatar
Madison TLS -- Your the best, thanks dude!!!
Old Jun 28, 2004 | 12:27 PM
TLP_2000's Avatar
A$IAN_CHICKEN
do you know if this resets the SRS light?
Old Jun 28, 2004 | 12:56 PM
dands99tl's Avatar
This will NOT reset the SRS light. You will need to go to the dealer to have your SRS system checked. If the SRS light is on, it's probably for a good reason, they don't typically malfunction.
Old Jun 28, 2004 | 01:40 PM
Pure Adrenaline's Avatar
Dragging knees in
This is all in your owner's manula, fellas. Doesn't anybody read it anymore??
Old Jun 28, 2004 | 01:55 PM
69ssrscam's Avatar
2003 SSM TLS
Owners manual?? What's that?? J/K
Old Jun 28, 2004 | 01:58 PM
evercn1's Avatar
Thanks Madison.
Old Aug 3, 2004 | 08:27 PM
Type TL-S 03's Avatar
9th Gear
does this work on the 99tl also? i have an 03 and i tried and it works. however when i tried on my friends 99 it wouldnt turn off.
Old Sep 18, 2004 | 10:26 AM
Ymiked's Avatar
9th Gear
Actually, the SRS light malfunctions are a real problem. Here is a reset procedure from another thread.
Here are the instructions for resetting the SRS light.
1. two wires green in a yellow block (small)
2. under dash left of steering wheel as the driver sits.
3. smaller yellow block is the right one and is located one inch above another bigger yellow wire block which has a spring loaded connector.
Jump it with the paper clip, turn the car on, wait for the SRS light to go off, yank the paperclip out. It'll light up again, shove the paperclip back in...then it'll turn off. Yank it out. It'll then blink twice to tell you it's reset.
Old Sep 18, 2004 | 01:11 PM
TeknoKing's Avatar
to continue what Ymiked has posted from another thread (thanx to DareIL for the instructions)
I cut a thin paperclip to about 2cm long, then bent it with needle nosed pliars so it looked like a staple. Then I just used the needle nosed pliars to push it in and out of the plug.
Takes about 20 seconds when you get the idea, good luck.peace.
Old Sep 19, 2004 | 01:01 AM
bkzjimmy's Avatar
NiGhT rIdEr
wut if there is really a problem wit the srs?????
Old Sep 19, 2004 | 01:56 AM
TeknoKing's Avatar
well, after you reset it, and the light comes back again, then you might have a problem. Knowing Acura dealership to diagnose and to fix the problem will cost you an arm and a leg.
My malufnction was that the yellow warning light, thats goes on when the passenger leans on the side of the seat, wasnt working right, i resetted the SRS, i check the sensor on the seat, and everything is fine now.
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
95legend6speed
Sep 21, 2015 06:40 PM
vbgregg
Sep 11, 2015 05:38 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
