Replacing positive battery cable DIY
Old 02-20-2013, 12:45 AM
Registered Enthusiast
emaka9's Avatar
Replacing positive battery cable DIY 99 TL
Whats up everybody. I've been on this forum for a few years and I haven't contributed any DIY's, so I figured it was time to show you guys what I can do. I have a couple DIY's and mod page I'm going to do for you guys. I hope this helps you guys out and it gets added to the DIY stickies so you can find it easily. Enjoy!
Alright so my original positive battery cable had corroded so badly, that it broke off from where it connects to the battery. I got the OEM positive battery cable from a friend at a local dealer. Figured I would take pics and make a DIY while I'm doing it.
Part number:
First things first, remove battery.
Next, follow the positive cable from battery down to starter, and back around to the under hood fuse box located in the passenger side corner. When you follow it down to the starter, you will come across a couple of green clips holding the wire down to a piece of metal. They're just clips, lift the unlock and pull them off the metal they are clipped to. Don't try to take them off the cable because the new cable comes with all plastic clips and those green clips.
You have to remove the cable from the starter. It's a 10 or 12 mm if I remember.
Now time to remove all the plastic clips along the frame to the fuse box (YES, I did break every single one.):
plastic clip removed
Lastly, remove the cable from the under hood fuse box (it's the left one):
Now pull the cable out, it gets a little bit tricky over by the intake box, but not a problem.
Here's the old cable out and the new cable in:
On the starter and green clips back in their places:
And finally, back to the battery:
Notes: In the end, the cable connector for the battery installed a little twisted, but you just work it around and you can get it turned up the correct way. Took me about an hour just because it was a little tedious with the clips and removing/installing the cable itself. I know my pics weren't the best, but my hands were greasy and I was on a tight schedule, and it was my iPhone, so I did the best I could for you guys with what I had. I hope this helped you guys out. Feel free to ask any questions as I may have forgotten things. More DIY's and my build thread coming soon!
The following 5 users liked this post by emaka9:
05_NBP_TL (02-23-2013), 3.2TLc (02-24-2013), Bricktop (02-23-2013), DiscountChrissy (02-24-2023), healeysa (08-02-2013)
Old 02-20-2013, 12:59 AM
Unregistered Member
Karanx7's Avatar
Very nice DIY!
Those clips are just gonna break. After 10 years, they are so brittle.
Old 02-20-2013, 01:34 AM
emaka9's Avatar
Originally Posted by Karanx7
Very nice DIY!
Thanks! haha ya they were shattering and exploding everywhere lmao
Old 02-21-2013, 09:44 PM
emaka9's Avatar
Old 02-23-2013, 04:23 PM
emaka9's Avatar
Bump
Old 02-23-2013, 06:27 PM
Mattila-The-Hun's Avatar
Great post....
Old 02-24-2013, 02:43 AM
Unregistered Member
Karanx7's Avatar
Ask Fatty to add it to the DIY list thread
Old 02-25-2013, 07:11 AM
emaka9's Avatar
Thnx guys. I will pm fatty.
Old 08-02-2013, 04:37 PM
healeysa's Avatar
Great DIY. Thanks! Does the new Cable come with all new clips? I got a good laugh out of your comment about breaking every single one.
Old 08-02-2013, 05:47 PM
emaka9's Avatar
Ya the new one comes with everything you need! Haha you know how those Honda clips are...
acutee (08-05-2013)
Old 11-24-2015, 08:13 AM
8th Gear
sam_acura_2012's Avatar
Thank you emaka9 for the diy! Yesterday, I replaced the positive battery cable. Now, the car starts right up in the 1st try. The old terminal was replaced because of corrosion. Lately cable leading to the terminal was fully corroded (totally blue). The diy took me about 2.5 hours because I don't have any experience working on the car. Just took patience taking out the plastic clips. The 1st green plastic clip from the starter was the hardest to take it out. Thank you again!
Old positive battery cable
Old 12-01-2015, 01:17 AM
emaka9's Avatar
Wow that is awesome! I am glad to see that my DIY is helping others! Props to you for doing it first time!
Old 07-20-2022, 10:07 AM
msl77's Avatar
Any videos on how to do replace the cable??
thanks
Old 07-22-2022, 01:31 PM
619rcr's Avatar
thanks
It's only a few bolts, 8mm, 10mm, 12mm. Disconnect the neg post. Remove the old cable from 3 points batt, fuse box and starter. Reverse process to install the new one. Done
Old 07-22-2022, 03:10 PM
msl77's Avatar
Yeah I didn’t realize it’s all right there! I thought the starter was on the bottom. Damn dealer wanted $500 😂 for an hour job and $75 part
Old 07-22-2022, 03:54 PM
Received 1,789 Likes on 1,437 Posts
OMG, that's .
msl77 (07-22-2022)
Old 07-24-2022, 11:41 AM
msl77's Avatar
Positive battery cable
Just changed this cable and it was super easy. Hardest part was getting the clips on. I can’t believe dealer was going to charge me $500!!! Assholes…
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 06:12 PM
Quick Reply: Replacing positive battery cable DIY
