Replacing Headunit
Old Sep 14, 2008 | 01:15 PM
MOBB's Avatar
Exclamation Replacing Headunit
I have a Pioneer Premier 6900 deck just laying around from my old car. I really wanted to put this into my 2000 TL because the stock radio doesn't read burnt Cd's. These are my plans, I want to change the head unit and retain the stock speakers and sub. I also in addition want to add 2 10" MTX sledgehammer subs.
The question is I want to know how the speakers will sound with the aftermarket deck will it sound better than stock and will it be louder than stock?? Also would I be able to keep the stock sub working with the aftermaket deck in addition to having the MTX subs put in.
I'm facing a really tough dilemma because I could also get a 2003 Head unit from my local junkyard.. and i'm stuck not knowing which one to go with. I love the sound quality of the stock system I really don't want to loose it and make it sound like a** with an aftermarket deck. If anyone could help me out making a decision of which deck to go with. Keep in mind im going for sound quality and loudness and making it sound just like stock.
Old Sep 14, 2008 | 07:25 PM
Forevafire's Avatar
The speakers will definitely sound a lot better with the aftermarket head unit. For improved sound though I would look at a set of components. I just put a set of Kicker components in my car and I was VERY impressed.
I do not think you can still have the stock sub working. I'm not sure though, I never have checked mine to see if it works because I put a sub in when I replaced the head unit. You honestly will not need to have the stock sub working if you put an aftermarket subwoofer in.
If I were you I would definitely put in the aftermarket head unit. I hated that mine could not play burnt CD's. I was very impressed with the quality and sound when I replaced the head unit. Now I'm not sure of the exact model of head unit that you have. But if it isn't too old you should see a big improvement in sound quality.
Hope this helps with everything…Good Luck
Old Sep 14, 2008 | 08:45 PM
Deepsiix's Avatar
2000 3.2TL
you will need an amp. the stock HU has one built in.
Old Sep 14, 2008 | 08:57 PM
Forevafire's Avatar
The Pioneer has one built in. Yes he will need an amp for the subs if that’s what you are referring to.
Old Sep 14, 2008 | 09:18 PM
MOBB's Avatar
the only scary thing is that I heard alot of people complaining about the stock speakers sounding like crap with an aftermarket HU because Bose already amplifies them to the max.
Old Sep 14, 2008 | 09:51 PM
Forevafire's Avatar
I kept my stock speakers for 3-4 months after I put in head unit. Also ran my stock speakers with a 10" sub and they stood there ground.
You won't be dissapionted if you put in a aftermarket head unit. The speakers will sound a lot better then they did with the stock unit.
Old Sep 14, 2008 | 10:36 PM
CAB NY's Avatar
Tri State ViP Crew
i added the Pioneer D3 with the stock speakers and they sounded a lot better with this radio then the stock also i kept my sub hooked up for a while until i added a new set up
Soul_Deamon
Nov 13, 2018 04:44 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
niray9
Dec 8, 2015 07:34 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
