Removing Headlight
Removing Headlight
My passanger headlight got cracked so I got another off ebay to replace it. I searched and saw that I need a Torx T20 Security Bit, but can someone post some step by step instructions to get the headlight off the car? I'm a noobie moron so I just don't want to break anything.
Thanks,
Chris
Thanks,
Chris
its pretty easy. remove the bumper like he said. then your see 2 or 3 screws on each side of the bottom of the headlights. i did this a long time ago, i dont remmber exactly. its not hard once u remove the bumper.
first, you need to remove plastic covers on top and bottom.you just need flat screw driver
Then you need to remove two 8mm bolts goes on the bumper.they are located by the tires on each side
Then you will be able to remove the bumper
Once you remove it,you need to remove 2 10mm bolts on top and 2 10mm bolts goes on the headlight.
then you will be able to removed the headlight frame.
by the way,you don't need torx socket
its pretty easy to do, can be in 20min
http://www.a****world.com/forums/sho...threadid=18740
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
