remove 3M tape solution HELP!!!
Old 02-21-2006 | 06:31 AM
InspireUA5's Avatar
極品インスパイア32V
HELP!
Is there any way I can use to remove the 3M tape on my car ? They are so tight and seem like non-removable?
any chemical stuff that I can use in order to remove those tapes but SAFE for the paint?
Thanks.
Old 02-21-2006 | 08:15 AM
InspireUA5's Avatar
極品インスパイア32V
does WD40 work fine for that case?
Old 02-21-2006 | 08:31 AM
NSXNEXT's Avatar
WD40 or Goo Gone works well. Just don't let it sit on there too long. They also make adhesive remover that works well. Check auto parts stores or talk to someone at a body shop.
Old 02-21-2006 | 09:22 AM
InspireUA5's Avatar
極品インスパイア32V
Thanks bro I will try this out....
Old 02-21-2006 | 09:27 AM
fsttyms1's Avatar
3M makes a great adhesive remover. Also use a heat gun or hair dryer to warm it up, it will come off easier
Old 02-21-2006 | 11:01 AM
InspireUA5's Avatar
極品インスパイア32V
Thanks fsttyms1
Acutally I have tried WD40... doesnt work for my case
Where can I get the "3M adhesive remover"?
Is it a spray?
The 3M tape on my car is so thin and there is NO such a gap between the body of my car and the tape...
Old 02-21-2006 | 11:27 AM
fsttyms1's Avatar
Originally Posted by InspireUA5
Thanks fsttyms1
Is it a spray?
its harder to find. I think (not positive) home dept sells it, some auto parts stores have it and most auto paint stores have it.
Try using a heat gun/hair dryer to warm up the tape. It will make a difference
Old 02-21-2006 | 12:16 PM
InspireUA5's Avatar
極品インスパイア32V
actually it's not the regular 3M tape....it's called 3M Reflective Sheeting which contains some sort of metal sheet in it. Really hard to get rid of it....
Old 02-21-2006 | 12:33 PM
fsttyms1's Avatar
doesnt matter, if its got adhesivein it the 3M remover works best. and seeing your in a cold area, heat will allow the glue to soften and the stuff to be removed alot easier. when its cold its REAL hard to get stuff of
Old 02-21-2006 | 12:52 PM
InspireUA5's Avatar
極品インスパイア32V
oh...i see...thanks for the info
i will check that out later
hopefully 3M remover won't be that expensive...
Old 02-21-2006 | 12:55 PM
fsttyms1's Avatar
No its not that bad.
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
Fool
03-10-2016 08:42 PM
xsilverhawkx
09-28-2015 06:51 PM
LoneRonin
09-28-2015 09:11 AM
AcuraKidd
09-25-2015 11:18 PM
Quick Reply: remove 3M tape solution HELP!!!
