Relay help
Old Mar 30, 2016 | 04:37 PM
Curious3GTL's Avatar
Relay help
I have a 2000 TL and I can't find the power steering pump relay for the life of me. I have an ABS light on and according to what I can find I need to start with code 53 with is most likely the relay.
I found this 01 02 03 Acura TL 3 2 Automatic ABS Pump Relay Box | eBay
So it clearly shows an ABS pump relay box, but I can't find this for the life of me under the hood. Any help?
Also any help with the part number would be appreciated too.
Old Mar 30, 2016 | 07:26 PM
From what I can see the relay design might have changed from 00 to 01-03? From all the diagrams I can find it's the box next to the fuses under the hood, but mine doesn't look like the used ones being sold on eBay.
Old Mar 30, 2016 | 08:13 PM
Okay, I am an idiot. It changed from 99-01 to the 02-03, and for some stupid reason went off a sellers description. I am still trying to find the part number, but it looks like a generic relay?
Old Mar 31, 2016 | 08:21 AM
01acls's Avatar
"I have a 2000 TL and I can't find the power steering pump relay for the life of me. I have an ABS light on and according to what I can find I need to start with code 53 with is most likely the relay."
^ Are you trying to locate the ABS relay and not the power steering relay?
Old Mar 31, 2016 | 08:27 AM
I was, and I realized I was looking at the diagram for an 02-03 which is different. However, the service manual states the the blow motor relay and the ABS relay are the same relay. I swapped the two and the blow motor still worked, so clearly it's not the relay. I am going to have to get a voltmeter to try somethings out to clear the codes.
jchiodi
Feb 1, 2018 08:22 PM
Acuratl3535
Apr 5, 2016 01:38 AM
04SSMnMD
Apr 4, 2016 01:55 PM
mattcl-s
Feb 3, 2016 08:44 AM
robpp
Jan 28, 2016 06:00 PM
