main relay harness
Old Jan 29, 2016 | 09:11 AM
mattcl-s's Avatar
main relay harness
Hey guys i have what i might think is a major problem. I put in new main relay thinking that will solve evrything turns out it did not. Its not the relay but the harness for the relay will not keep a connection and the car keep dying not sure how to fix that please help
Old Jan 29, 2016 | 09:20 AM
mattcl-s's Avatar
when I hold the harness/connector in a certain position everything works fine but when I let go the car shuts off. I can feel the relay clicking on and off when I do this
Old Jan 29, 2016 | 11:12 AM
mattcl-s's Avatar
anyone have an opinion?
Old Jan 29, 2016 | 11:25 AM
Clean the pins on the harness. Maybe there's some corrosion not giving it a nice strong connection
Old Jan 29, 2016 | 11:30 AM
mattcl-s's Avatar
I will try that when I get back home later today, I am keeping my fingers crossed!
Old Jan 29, 2016 | 06:02 PM
mattcl-s's Avatar
I am positive i identified the problem and its the ground wire on the connector somewhere in the brown casing its losing contact with the prong on the relay. Any ideas on how i might fix that? Please share you thoughts
Old Feb 1, 2016 | 10:54 AM
mattcl-s's Avatar
So I did some messing around with this weekend, had I running for a bit Friday night seemed like the ground wasn't making a good connection. I wound up messing it some more then the relay wouldn't click on at all i gave for the night. Saturday i went a bought a light tester to see if it was even getting power when I put on the green/white stripe it would light up so im assuming that was the power one, but none of the others lit up. there was one fuse also in the fuse box area a brown 7.5 fuse wasn't lighting up when i put the test to it so I replaced the fuse and it still didn't work? so now im finally going to take into a shop I did all that I could so well see what happens
Old Feb 3, 2016 | 08:44 AM
mattcl-s's Avatar
shop called me today said it was a wire in the connector that was broke somehow all and all 95$ later I have a car again!
robpp
Jan 28, 2016 06:00 PM
DJMikeT
Jan 12, 2016 12:15 AM
