Redline ATF?
not really true...if you talk to the redline guys hypethetically they'll tell you there are benefits...they say what they say to avoid liability issues with hondas warranty and hondas exclusive use of an additive called z1 (if my memory serves me)...im told to use a dexronIII type fluid available from redline as well as many others will cause a firmer shift..but you may also experience a shutter i say may as even the honda manual recomends dexronIII in the absence of honda fluid being available,but ,then does go on to say to switch back to honda ...if you're only doing a 2.7 quart fill i dont think there would be any negatives...just my opinion
Can anyone report on switching to one of the synthetics (Redline or Mobil 1 ATF)? Also, we should find out what "Z1" is and does. It might be marketing hype, but then again it might be some special additive that the transmission needs.
vpasla1
09-17-2016 07:24 PM
EvilVirus
12-10-2015 07:38 PM
