Red "BRAKE" light on dash, when pressing brake pedal
When I started my car this morning and left the driveway heading for work, I noticed that when I press the brake pedal, a red dash light came on with the word "BRAKE". As soon as I came closer to stopping at a stop sign, or when letting off of the pedal, the light would go off. It would come on every time I pressed the brake pedal, but after about 5 minutes of driving, I didn't see that light again.
The brakes worked perfectly fine. I didn't notice anything unusual about them. I pressed them harder than usual, just to be sure. But I generally try to be light on the brakes (as well as the accelerator).
I haven't checked the fluid yet, but I plan to do so today. However, why would it only be intermittent rather than constant if the fluid were low? When I drove the Impala and the fluid got low, the "BRAKE" light came on when I would turn a corner. Filled it up once and never had that problem again. I just don't understand, even if it's just a little low, why the light will come on when pressing the brakes, but not again after about 5 minutes of driving.
Im not sure if the TL has a separate warning lamp for brake light bulbs, so it could be telling you there is a bulb out as well....have someone press the brakes while you are standing outside the rear of the car and make sure you get all 3 lights coming on (repeat the procedure with the headlights on just for good measure)
binary_10essee (08-08-2014)
Check your brake fluid. You are probably low (usually a sign that your pads are wearing enough to lower the level. Also check the float on the cap. It has known to stick slightly causing the light to come on intermittently
Thank you both for the detailed info. I'll check the fluid levels, check beneath the vehicle for any sign of leaks, check the lights themselves, etc. I'll come back once I figure out what's going on, or if I need more info. Thanks!
start with the master cyl cap- that float loves to stick or otherwise fail
to test- flip upside down and observe motion plus light activation
about 35$ for a new cap
based on your cars extensive need of TLC I would not be surprised if the brake fluid had not been changed frequently
For reference the owner book says 1 time EVERY YEAR, or every 3 years MAX! time between brake fluid flush
old fluid has many problems- wiki hygroscopic for info
we do have a separate Brake LAMP out (brake light) warning light
I just checked the fluid and it's right where it's always been. Is there anything I should look for in the fluid, in terms of color or anything? I'm having lunch with a friend of mine today so I'll have him check the brake lights themselves.
Sounds like the float on the cap was stuck slightly. Make sure it moves up and down freely. That is the only thing that will set the light off. That light wont come on if your brake lights are working or not. That is a different light and would remain on if a bulb were burnt out.
Some of the TSX guys had this problem, nothing wrong with the brakes but the light would come on in the morning and go away after a short period of time.
If your pedal is soft or braking is not what you think is right have it checked out.
the brake fluid is a clearish amber color to start, it quickly picks up dirt color and becomes darker- mucky looking inside cap area
if its dark its ready for a flush
reminder to all first time brake flushers/bleeders: special order for the tL is unlike any car I worked on before !!
Driver front then clockwise around the car = LF RF RR LR
due to ABS plumbing I believe
the vac tool method is awesome for moving the total number of ounces of fluid you want pulled thru the system, so its clean clean not just -clean with no bubbles after a few ounces
there is a lot hidden and you want all of it!
If you buy 2 qts of DOT4 you have more than 16oz per caliper available!
the bleeder cup holds 4 oz A really good 4 wheel flush job takes about 1.5 qts of fluid
01tl4tl (08-10-2014)
I hope everyone knows by now to clean the screen filter thing inside brake master cyl when they flush the brake fluid,,every year..at least once every 3 years
that should cut down on the venting issue described in acura service bulletin EE4 linked
I haven't encountered the issue since the morning I first saw it. I checked the cap on the brake fluid container the next day, just in case. Everything looked fine. Haven't seen it since, really unsure of what caused it.
clean and tighten the wire connectors to cap
assume you did ck fluid level is at top indicator?- right at the neck basically
a quick spray of brake cleaner thru the filter screen wont hurt and takes a few minutes
noobs: remove screen and clean away from car- must be dry dry before install
mada51589
05-03-2022 08:54 PM
09-04-2015 08:03 AM
