Recommendation fluid to flash Transmission and Brake fluid
Hi
Friends
Yesterday i visit my mechanic for the general inspection and low beam headlight bulb replacement
After inspection he told that transmission and brake fluid needs to be replaced and also hood strut was also not holding the hood.
Kindly tell me
which fluids are high recommended for flashing/replacing transmission and brake & what are they called
From where i can get them (fluids and hood strut) cheap
thanks alot in advance for your precious help
Hee dehis
Friends
Kindly tell me
Hee dehis
A) Don't flush your transmission do a 3x3 with HONDA DW-1 ATF ONLY!
B) Brake Fluid needs to be properly replaced in each wheel with your brand of choice and flavor: DOT 3, DOT 4 and DOT 5.1 will do the trick.
C) Hood Struts can be found on (Click Link)
Hope it helps.. Later!
Amazon.com: Qty (2) ACURA TL 2002 2003 Gas Charged Hood Lift Supports, Struts, Shocks, Dampers: Automotive
Go to your local Honda parts department, ask them to price match internet pricing on a case of DW1 ATF. They will normally do a better price on a full case than by the single quart. Buy an inline tranny filter also while there.
As Skirmich previously stated: Don't flush tranny fluid, but do the drain & fill method !!!
The tranny fluid and brake fluid replacements are a simple process. Check the "DIY" sticky for tips.
Heedehis (05-19-2014)
Thanks alot for Guidance cum help
you forum member are great i got help earlier for headlight bulb replacement and go through and watch couple of video of replacing the bulb it help at the mechanic shop
As he told that it is long job he has to remove the bumper and remove the headlight it is long BLAH BLAH
But when i showed him the video it literally takes 20 min max to do all the replacement
coming back to point
how many quarts of HONDA DW-1 ATF i need to replace transmission fluid and which is recommended brake fluid DOT 3, DOT 4 and DOT 5.1 and how many quarts for flushing brake fluid
Hee Dehis
Hee Dehis
They are different temperature Ratings being
DOT 3 the Weakest
DOT 4 the Upgrade
DOT 5.1 the Strongest
DOT 5 < DONT USE IT! NOT COMPATIBLE!
But they come up in price the higher the DOT Number so its up to your wallet.. Make sure though if buying the DOT 5.1 that its in fact "5.1" its really important as DOT 5 don't work with our braking system and can destroy many seals! DOT 5.1 is what you want dat point 1 is really important.
DOT 3 the Weakest
DOT 4 the Upgrade
Heedehis (05-21-2014)
buy 10 or 12 qts to do it right
total per change approx. 3 qts to 3.5 and you want to make it perfect when done
read owner book or see on here the correct book procedure for change-
drive MAX 5 minutes using each gear then stop and drain fluid again- repeat until done
total capacity is 9 qts of which it will give up 3 at a draining
if you have ANY slippage of trans now do NOT proceed
average mechanics= especially guy who didn't know how to do your headlight
should NOT be trusted on the atf condition
Ask a Honda or acura parts guy or tech for opinion
How many miles on trans- is it a replacement trans ? any known fluid change- color and smell now?
brake fluid get dot4 for normal humans- it may say dot3/dot4 as its really 4 and covers all of 3 specs plus more
5.1 is for racers,, not average driver and its 15$ a qt
plain ol or synthetic- your choice of Dot4 of any brand name is fine at 3 to 5$ per qt= get 2 as said above
note SPECIAL!! TL brake flush/bleed order is LF RF RR LR
driver front then clockwise due to abs plumbing
failure to do this order means it was not done right
trust no tech that cant tell you this special order
for sure Honda on the PS its one of the real picky systems
see our diy section for help,-,attach a garden hose sized hose OVER the return line for ps to res (use hose clamp ),,pumps out into 1 gallon jug
Place cardboard under front wheels to lower resistance while turning them
May be a good idea to fully flush system 2 times if 100kmiles or more and never done before
free owner books with diy-capacities, help at www.owners.acura.com
mada51589
05-03-2022 09:54 PM
ulrblitzer
09-24-2015 08:42 PM
