Rear Main Seal
Old Sep 10, 2008 | 05:38 PM
TL1668's Avatar
Rear Main Seal
I have 2000 TL that is slowly leak motor oil between the engine and transmission. Has anyone replace the rear main seal for their TL? Thanks for any help.
Old Sep 10, 2008 | 08:31 PM
Rajca's Avatar
wham bam thank you ma'am
mines leaking too. not bad yet.
Old Sep 10, 2008 | 08:56 PM
01tl4tl's Avatar
requires removal of the transmission to access engine rear main seal
Its about 4-5 hours to R&R the trans~ and it weighs 450 pounds!!!!
This is a good time- if covered- to have a traumatic trans failure under warranty!
Then its an extra few dollars and 10 dollar seal from your end while they install a 4000$ transmission for free
Old Sep 10, 2008 | 09:00 PM
01tl4tl's Avatar
TL1668 call acura and register- ask what the first date in service was
The trans warranty is 7 years PLUS 9 months from first date- OR 109- or 114.5 miles
depending if you are part of the odometer overreads vin set- many of us are!
1-800-382-2238 x5 gets a human.
Need your VIN number in hand to register
Old Sep 11, 2008 | 12:59 PM
TL1668's Avatar
Thanks for all your replied. Acura replaced my car's transmission around 85,000 miles, now my TL has 120,000 miles. Is rear main seal leaks common to second generation TL?
01tl4tl, just woundering why do I need to register my car?
Thanks again!
Old Sep 11, 2008 | 01:19 PM
01tl4tl's Avatar
if there are future recalls acura will have your name as the owner- thats why you register
You can read things about recalls and make sure your car has been taken care of on those
The engine rear main seal is known to fail from time to time
Its not every car,,, or they would suggest it when the trans gets replaced
PITA job for a 10 dollar part- remove trans to access
Old Sep 11, 2008 | 01:42 PM
fsttyms1's Avatar
Thanks again!
rear mains are most common to the 2003. Unfortunately it requires removal of the trans for a 8 dollar part. Its all labor but the dealer could do it in 4 hrs.
Old Sep 12, 2008 | 05:58 PM
TL1668's Avatar
Do you guys know how difficult to remove the seal after the trans is out? Does it require any special tool?
Thanks.
thegipper
Oct 21, 2015 07:19 AM
IIDXholic
Oct 8, 2015 07:53 AM
Sep 21, 2015 08:44 AM
Sep 17, 2015 09:01 PM
Sep 17, 2015 08:57 PM
