rear door panel removal.
Old Apr 5, 2008 | 10:15 PM
Toronto_99_3.2tl's Avatar
hi guys, i noticed today that my rear right door doesnt unlock or lock with power (remore or drivers switch) i wanna take the door panel off and take a look...can any one point me in the right direction for properly removing the door panel without damaging or breaking anything? i know alot of the time there are hiden screws and clips....
thanx in advance
Old Apr 5, 2008 | 11:02 PM
MurkyRiversTL's Avatar
COTM Coordinator
behind the interior handle there is a little circle cap. remove that with a thin blade screwdriver. then take a phillips head screwdriver and remove the screw behind the circle cap. once screw is removed, push the door handle section forward towards the fron of the car and it will slide then pull out and you will see the rod going to the handle. where the rod meets the handle there is a little connector that you have to unclip off the rod, then pull the rod out or up to remove the handle. then under the armrest part you will see a hole insert a phillips head screwdriver and remove that screw.
then you put your fingers in between the panel and the door and pull out. don't be afraid the clips will pop loose before you braak the panel. once its all looses. lift up to free it from the door lock. then diconnect the connector for the window and your done.
sorry for my spelling and lack of punctuation but im typing all this on my phone while on the shitter.
yes im multitasking lol.
Old Apr 5, 2008 | 11:28 PM
slavver01's Avatar
03 ABP tls
wow, now im really impressed!! thats dedication
haha but yea, what he said
Old Apr 6, 2008 | 02:26 AM
thats awsome. thanx buddy
Old Jun 2, 2008 | 11:29 PM
willyfive's Avatar
is it the same procedure to remove the front door panels?
Old Jun 3, 2008 | 07:34 AM
fsttyms1's Avatar
Pretty much.
Old Jun 3, 2008 | 10:40 AM
SSTL's Avatar
Awesome Memeber
thanx in advance
My rear right door has the same problem, please let me know if you were able to find out what the problem was.
Old Jun 3, 2008 | 10:51 AM
Cisko TLS's Avatar
B A N N E D
throw your car away lol.....thanks god my door doesnt have that problem
Old Jun 3, 2008 | 04:24 PM
WillrunifChased's Avatar
The ICEMAN
That is the reason I will be getting a laptop next...
uzzmaan
Aug 4, 2025 08:29 AM
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
govtcheez
Oct 1, 2015 12:21 AM
CadiGTi
Sep 14, 2015 06:37 PM
