Rear Brakes
Rear Brakes
The car's in the shop getting a new tranny; they said I have less than 10% on my rear brakes. I have a previous post from where I did my front brake pads and installation of new Rotora rotors. It was a pain in the #$@! to get the front rotors off--had to drill them out.
Anyway, I read the DIY on replacing rear brake pads. Comparing them to the front, how difficult are they? I am not replacing the rear rotors. From the DIY write-up, they look comparable except you have to bleed the brakes. Also, does the rear caliper piston just press inward or does it screw inward? I think some Fords are like this and you have to have that special tool.
I always do my own brakes but after last time, I don't know if I am going to worry with it or not. Any suggestions?
Bleeding-flushing the brakes before working on them provides extra protection against bad stuff in system backwashing and destroying caliper- Flush all brakes first then do the brake job
bleed order is LF driver front LF RF RR LR
just 2 bolts hold the caliper on- lift off- remove pads, clean and grease retainer springs and slider pins, grease pad backs- install
the piston pushes straight in- clean it well!!
see www.heeltoeauto.com tech articles for pad bedding
yes its the same setup as the fronts- just smaller bolts and lower torque spec for same
Annual flush of the brake fluid is recommended after 3 years, more often if you use the brakes in a life or death defying driving style
