really unique situation. help me out please!
here's the deal. the bass/balance knob on my stereo is broken and I cant adjust it. I don't care about the bass, its the balance control I'm worried about. My rear speakers don't work (two door and the subwoofer). Absolutely nothing comes out of them. I'm wondering if my balance switch is turn all the way to the right (giving sound to only front speakers). Since I have no way of checking, I am asking for your guys' help. Could you go into your car and adjust the balance (push in the bass knob until it pops out (bass), and then pull on it until it clicks (balance), then adjust left/right) so that the sound is directed to the front speakers and tell me if ANY sound comes out the rear door speakers or if the subwoofer still works. If so, then I will know there is something wrong with the wiring. If not, (nothing comes out the back speakers and sub when balance is adjusted) I will know that I need to adjust the balance or get a new stereo. Thanks for your help!!!
actually, i own a 3g TL and the sub does not work when balance is changed to the front..only the front speakers..mite be diff on the 2g..but this is my so i think it just might be ur balance thats tweaked a bit..try and get it working and adjust it before you take it to someone
nope, i found out that fade controls front/back and balance controls left/right. adjusted the balance on mine and sub still doesn't work.. might get someone to look at it. oh well, at least I have 4 speakers now..
Originally Posted by Gfaze
Open your trunk and look at the subwoofer. Make sure the wire harness is still fully plugged in to the sub. You may have knocked it off at some point.
Well you're sub wires are missing!! That connector that is hanging in your trunk is the sub wiring. There's supposed to be a small 2"-3" wire harness that plugs into it. The little harness has the connector leads for your subwoofer. You could probably go to your local Acura dealer and have them order it for you. I doubt that they keep it in stock. Once you get that you should have a working sub!
Originally Posted by MurdaZ
see the sub, thats the wiring hanging out...
i have one, gotta find it...cause by the looks of it u gotta buy the whole sub..
on the back of the sub, the 2 terminals (positive+, and the negative -) the plug has two wires to conenct on that, and the other end goes into the female plug on the other pic
I looked around on a few Acura parts web pages but I couldn't find the little harness that you're missing. You might have to drive your car to the dealer and point it out to the parts guy. Another thing you could try is getting a printout of the wiring diagram of that specific harness from them. That way, you could figure out how to splice into the wiring on your connector (that's hanging in one of the pics) and then connecting it to the sub. I took a picture with my cell phone so it's not that great but it should help.
Originally Posted by co1063
Thanks for all the help gfaze, hopefully I can get the harness from murderZ, if not, i will try what you said. i have no idea why the last owner decided to take it out..
No prob, happy to help.
wusty23jd
09-24-2015 11:41 AM
