rattling woofer (searched)!
TL Q(
ran a search couple of time already, couldn't find a solution to it. it's so annoying once you jack up the volume w/ some bass....
i'v try to stick some soft cloth under it, didn't work i couldn't even locate the exact location of the rattle now w/ all the fustrations
<S.O.S>
<S.O.S>
99TL-p 114K
I HEAR YA, i hate that rattling from the stock sub back there, sucks. I tried sticking some thick foam in the underside of the trunk area around there to silence some of that but it did NOTHING. I don't even think it can be silenced really.
is it the cover? try taking the cover off and see if that stops it
W00t
I have a similar rattle, but its comming from the ceiling of the car towards the back, like my lining is loose or something. I tried pressing around the sides to see if it was a loose clip or something. So while we're on the topic, what could I do to make it stop?
99TL-p 114K
Originally Posted by optomos
The metal on the deck is very thin and the covers are made of some sort of pressed fiber board that resonates like a harmonic tuning fork. This is what I did:
TL Q(
TL Q(
Originally Posted by NSXNEXT
can't see Optomos' pictures but what I did was dynomat the rear deck.
Originally Posted by wmah523
thx NSXNEXT! can you be more specific, me w/ low IQ/EQ hard to pick up things...
NiGhT rIdEr
take the cover off and see if you can get more foam tape under it to keep more upward pressure on it to help from rateling
What I did was tapped around on the metal deck and wherever it resonated the most I put down small pieces of matt. After that I put down 3-4 layers of liquid deadener. I also put 4 layers of the liquid stuff on the two covers and plastic center piece. I found that the covers resonated the most.
Received 1,080 Likes
He bought Dynomat and covered teh rear deck area. Dynomat is used for sound purposes and helps eliminate rattles and vibrations.
Si senor. Muchos gracias.
W00t
id find out whats ratteling? is it a wire up there? is it a drain line? is it just loose? find the culprit, then fix whats necessary
IBankMouse
06-13-2020 12:53 PM
MetalGearTypeS
08-29-2016 08:28 PM
kb1rl
09-30-2015 10:17 AM
