Radio Won't Turn On
Radio Won't Turn On
My stock stereo in my 02 TL-S won't turn on anymore. No indication on the display or anything. I checked the "ACC (radio)" fuse, "ACC Relay" fuse, and all fuses that listed "navigation" in the book (even though I don't have a navigation system). They were all fine. I searched around but all of the solutions were fuse related, so any suggestions would be appreciated.
what was the last thing that happened before this?
battery replaced,,dead batt jumped etc
fuses- are you swapping in new fuse or just visual?
get out the test light/multimeter and see where there is power
our radios are known to suddenly die,,usually its the cd portion-- but,,,
Crazy.. but the same thing just happened to my stock radio as well. No power.. fuses were swapped out, cig lighter gets power, and I can hear the changer cycle thru when I start the car, but no sound, no display, nothing.
Ive searched, and some say that a coin may have gotten jammed up into the back of the radio from the coin tray.. Any one have other advice?
Here's my latest... I held the 1 and 6 down for maybe ten seconds and it flashed between L(4 numbers) and R(####) then, it displayed the C0dE. I can now enter my code and hopefully it will work. I don't have my code and the Acura dealer said they can't get it with just my VIN. I now have to take it some place, get the unit removed so they can get the serial number then, provide the SN to Acura along with faxed or emailed proof of ownership so I can get that sacred code. Who knows what that hassle will cost. The CD player is crud anyway so I am considering a new nice looking (nothing gaudy looking) unit to replace the stock equipment. Any suggestions in that regard?
Before you do that, remove the 2 pieces of wood grain trim around the radio, and possibly remove the driver and passenger plastic covers (going to the floor) around the radio. The sticker with the serial number is usually on the front or the side of the radio and you don't need to remove the whole unit.
That is how I found my serial number and the dealer looked it up for free. They said they did a favor for me because they usually charge $120 to lookup the radio codes on the system.
What did the dealership fix? For my 99' Accord(R.I.P)(somewhat similar car) they replaced the ECU when it had your same problem of not being able to take it out of park. If they replaced your ECU, I would have the dealership reprogram(FOR FREE SINCE THEY REPLACED IT) your new ECU. I can't guarantee it will fix the problem because i have no idea if the ECU plays a part in the radio functioning but its worth a shot.
Wow that was surprisingly easy to get. I actually did it waiting at the drive thru! Glad I didn't pay to take it somewhere, thanks for that suggestion! Can't wait to get the code from the dealer tomorrow and see if the stereo works. I have no idea how it lost power/reset itself in the first place. The battery has been completely fine. And QueenCityTLS, the ESU wasn't replaced.
Radio turned off and didn't power back on hasn't worked since
I was listening to the radio and suddenly I just turned off when I try to turn it back on and did not want to power back on and hasn't worked since and just to let you know I did get my battery replaced a couple hours before that happened on the same day so I was wondering if it's any hail related and what they should might be please help thank you????
rockyboy
Aug 4, 2024 10:35 AM
handsom-hustla
Nov 13, 2015 05:04 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
