Radio wants a CODE!?!?!
Old Jun 6, 2004 | 05:16 PM
etxxz's Avatar
@ slide or die @
Yup, i was putting an Injen 2pc CAI on my car yesterday and I was having trouble reaching a nut next to the battery so i decided to pull it off... I finish and take my toy for a test drive. Then, both my NAV and my radio ask for a "CODE". I found the NAV code on a little sticker-paper the dealership gave me when i updated my GPS but no radio codes...Does anyone know how can i find this out if not what it is?
Oh, the intake is amazing, everyone should have one! it makes a sound that could scare Carrera GTs away, it makes my engine sound like it has 900HP in it even though the power gains are very small (w/ 4.5ppl onboard (lil bro) and a full tank)
Thanks in advance duds.
Old Jun 6, 2004 | 05:23 PM
superballs's Avatar
this is usually in a wierd place. like on a sticker stuck to the bottom of the cupholder. or something.
Old Jun 6, 2004 | 05:58 PM
orcaatk's Avatar
There's usually a card with both codes in your cars instruction book. If you can't find it at all, you can bring your car to a dealer where they can look it up for you (but I think they need to take the HU out or something - dunno if they can run it using just your VIN or not)
Old Jun 6, 2004 | 06:21 PM
seattle dale's Avatar
thought i heard the code was on a sticker in the glove box.
Old Jun 6, 2004 | 08:06 PM
UA5-TL's Avatar
You should be looking in your leather covered car instruction book there a card should have your code
Old Jun 6, 2004 | 08:30 PM
Natismati's Avatar
Call up your dealer. Give them the serial number to the radio. They'll make sure you own the car, and give you the code.
Old Jun 7, 2004 | 12:53 AM
tweedle99's Avatar
The code might be under the fuse box cover under the hood on the passenger side. At least mine is over there.
Old Jun 7, 2004 | 06:22 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
my code is no where in my car. no where. its not even on the back of the radio. that really pisses me off. what i did though was called the dealer (as recommended by natismati) and once i faxed them proof of ownership they had it to me in about 20 minutes. good luck!
SSTS
Old Jun 12, 2004 | 01:57 PM
etxxz's Avatar
@ slide or die @
yup, i just called the dealer and had to give a ton of info and finally got some codes. the sad thing is i waited almost a week!!
Old Jun 12, 2004 | 03:28 PM
ABBOUSHI's Avatar
I got 99 Problems
ok i called my nearest dealer, you take your car over to parts dept. show them proof you own the car and they can give you radio code from your car VIN. and radio serial #.
Old Jun 12, 2004 | 04:22 PM
Pure Adrenaline's Avatar
Dragging knees in
Except you have to take the radio unit out of the dash to get to the serial number.
Old Jun 12, 2004 | 05:48 PM
parvo99's Avatar
On my 2003 you can hold the 1 and 6 preset button at the same time while turning on the radio, and it will flash the serial number on the display.
Old Jun 12, 2004 | 07:42 PM
awood's Avatar
Wow - I hope it doesn't do that when its in the mode where it needs the code! Otherwise; it would be a little pointless.
Old Jun 12, 2004 | 08:04 PM
parvo99's Avatar
Yes, it does it when you need the code. It flashes the serial number, not the code. That way you don't have to take out the entire radio to get the serial number. If you're worried about a theif getting the serial number too easy, it doesn't matter, if it's stolen, it's already out of your dash, and they can just get the number from the back of the radio.
Old Jun 13, 2004 | 11:18 AM
awood's Avatar
Ahh. Misread your post - sorry. Thanks for the correction.
Old Jun 17, 2004 | 08:08 PM
rocket6871's Avatar
code location...or on mine anways...
hope this isnt too late, but my code is located on the side of the glovebox...sit in the drivers seat, open the glove box and its on a little white sticker...navi code and radio code....hope this helps, and i hope this is the 'universal' acura way
Old Jun 18, 2004 | 10:28 AM
etxxz's Avatar
@ slide or die @
oh...i see it...but i cant try it out since my radio is working now...the thing is, the NAVi code was the same but the radio code is different...maybe the dealership gave me an universal one....everyone try thisone 35353.
Old Jun 18, 2004 | 02:58 PM
billmatt's Avatar
Contact NSA for that code!
dirleton
Aug 6, 2024 08:19 PM
Jamus22
Jun 11, 2023 10:08 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
