Radio isn't take code!
Old Dec 5, 2007 | 08:45 AM
thisisnotdave's Avatar
Porkchop Sandwiches!
Well, i just got my car back from the body shop, and they reset my radio. But for some reason, the code I have (which ive used before) isnt working. Is there any reason this could happen? Man this car is just driving me nuts.
Old Dec 5, 2007 | 09:21 AM
Bob_F's Avatar
You might have to pull the antenna out of the back of the radio. Search the forum for more details.
Old Dec 5, 2007 | 10:36 AM
ssmith500's Avatar
keep the antenna out while your punching in the code. After it recognizes it, plug it back in.
Old Dec 5, 2007 | 12:46 PM
Hmm, it took 3 reset but then finally took the code (30 tries!). WOW, this car is freaking possessed.
Old Dec 5, 2007 | 12:52 PM
obidon's Avatar
7th Gear
I'm currently having the same problem.
My ipod cable caused my radio to lock up.
Input code, wasn't working.
When I changed my headlights, my battery was unplugged for quite some time
Input code after putting everything back from changing headlights
Radio works
Radio randomly locked again (I suspect due to ipod cable again...wish I understood what everyone meant by saying to use the blitzsafe)
Tried code, won't work again.
Really crappy experience which is making my ipod cable experience even worse.
Old Dec 5, 2007 | 12:56 PM
Bob_F's Avatar
Radio works
Which ipod adapter/cable are you using?
Old Dec 5, 2007 | 01:10 PM
obidon's Avatar
7th Gear
Dice i-Honda-R2
It's not very good at all. I wanted to play with the features, but in the end it is not worth the hassle I have been going through. Next time I will listen to what everyone says as they are saying it for a reason.
Old Dec 5, 2007 | 01:34 PM
merkin110's Avatar
I had the exact same issue and all I did was removed the radio fuse from the passenger side fuse box and then enter in the code.
Old Dec 5, 2007 | 01:55 PM
obidon's Avatar
7th Gear
I will try that when I get home from work, thanks!
Uh, almost forgot. I don't have a manual, would you happen to know which one it is? Otherwise I hope I have a listing in the fuse box.
Old Dec 5, 2007 | 02:35 PM
merkin110's Avatar
It is listed in the fuse box.
Old Dec 6, 2007 | 07:44 AM
obidon's Avatar
7th Gear
Worked like a charm, thank you!!
Old Dec 6, 2007 | 09:08 AM
Bob_F's Avatar
Thanks for the tip. That's a lot easier that pulling the antenna cable.
Old Dec 6, 2007 | 11:19 AM
Type_S's Avatar
Sometimes you have no choice but to pull the radio antenna, like what happen to me. Since everything else didn't work.
Old Dec 6, 2007 | 11:24 AM
Bob_F's Avatar
Thanks for the info.
Old Dec 6, 2007 | 04:16 PM
disconnecting the battery also reset your the number of tries.
Old Dec 9, 2007 | 03:35 AM
Tech7427's Avatar
Under your Acura...
this is a known problem of the tl radios, if your under warranty go get it replaced
Old Dec 9, 2007 | 09:19 AM
fsttyms1's Avatar
Most here arent.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Skirmich
Oct 1, 2015 12:59 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
