Radio Code
Radio Code
Hi, I just had some work done on my car (New transmission) but since they disconnected the battery my radio is asking for a code. I turned it on holding down the 1 and 6 to get the serial number and called the Acura customer support and got the code m, but it didn’t work. Verified the codes with a local dealer, still not working. Any ideas for what I can do now?
Specifically
Pretty sure the code is specific to the radio, so if you don't have the code for that unit or the VIN of the car it left the factory with, then you are SOL. I may be wrong.
- Turn the vehicle's key to the "on" position.
- Press the preset buttons 1 and 6 at the same time.
- Turn on the radio.
- A 10 digit serial number will appear on the radio display, (if stereo was locked up at the time).
- There will be 10 characters in the radio serial #.
- A U followed by 4 numbers and an L. followed by 4 numbers.
- Example, your display will indicate, U5123 L1235.
- Or will indicate all 8 numbers at one time. Example: 12345678.
- Please document this number, as you will need this number for the form below (((CAVIEAT!))) I have never used this service, so i can't verify it. Another option: I believe, someone on this forum, posted a list of many radio security codes, which you could try, individually. Such an attempt may be time consuming because after several incorrect attempts, the security system will temporarily lock you out, for a period of time, before you can continue to enter more codes. I have never tried the Radio Serial Number retrieval method listed above, but if it works, it would beat all other methods of getting it.
TSX_Total_Noob
12-09-2011 12:40 PM
piggydog
02-11-2010 11:05 AM
hydro
04-06-2009 01:03 AM
tsxnation
04-19-2007 03:30 PM
