radiator flush
i bought antifreeze from an auto parts store(the green lime one)
to perform a radiator,while the engine is cold,remove the radiator cap,remove the radiator plug(under the car)let it drain,empty the resevoir(bottle next to the rad)
you can put a hose down the rad to flush everything out,put plug back on,bottle back in place,and refill i went with 30water/70antifreeze.
it is recommended to use Honda anti-freeze because again, proprietary formula made by Honda. frankly, i don't think it would hurt to use off the store anti-freeze. mix properly and change every two years. this is a DIY. look in your manual to find the radiator plug underneath the front fender.
ah.. i get the concept.. but i dont know what/where the radiator cap/plug/resevoir is... sorry guys, but i don't know what much about cars. trying my best to learn everything. does someone have pics of steps? or just pics of the ca and plug and resevoir.. ?
btw, i dont have a manual... bought the car w/o one
radiator is in between the headlights it has aa aluminium cap,the reservoir is on the right side in front of the battery,withe bottle wich should contain lime or pink fluid. before you remove the radiator cap MAKE SURE THE ENGINE IS COOL cause the fuid can splash on your face and burn you if the engine is too hot.
STL TL-S
09-23-2015 08:52 PM
