Radiator Fan Noise
Old Sep 4, 2009 | 01:16 AM
harminder247's Avatar
:( Harminder Is Lost In
Radiator Fan Noise
I was wondering if any one else has had this problem. I noticed today my radiator fan makes a whining noise when starting and shutting off. I opened my hook and see that the fan shakes back and fourth about a half inch. I havent driven the car since i noticed this. Is this bad? Can i damage something from driving? Only makes noise when its at a low speed starting up for shutting. When cars started the fan makes no noise. Is it a easy fix? Thanks in advance.
Old Sep 4, 2009 | 05:25 AM
01tl4tl's Avatar
pull the fan assembly and check the blades on tight
If thats ok- check shaft looseness from wearout causing excess movement
Old Sep 4, 2009 | 05:45 PM
Everything seemed ok but made the noise still. i have sound clips if youd like to hear. only makes noise when fan kicks in. anyplace u can upload clips or email if someone might be able to help?
Old Sep 4, 2009 | 07:41 PM
spoka's Avatar
It's possible the bearing is just warn out
Old Sep 4, 2009 | 08:21 PM
acurabum's Avatar
Lubricate the bearing and see if the noice goes away.
Old Sep 4, 2009 | 09:33 PM
01tl4tl's Avatar
Deep Creep thru the opening into the fan motor~ no kidding
its an electrical contact cleaner and water displacer like wd, plus leaves a protective type of oil behind (per their website on those facts)
the bearing is sealed iirc
MrHeeltoe
20
Feb 23, 2023 01:54 PM
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
