Radiator crack
Old Sep 29, 2018 | 12:10 PM
Chiller2002TL's Avatar
Angry Radiator crack
After spending 140 on a new battery and saving for my AV6 my radiator decided to crack.. I'm convinced my car hates me... Anyway I'm getting a Denso off Rock Auto for $60.. Question is I see people mention having to bleed the system after replacement?
I don't have the fancy no spill funnel or intended on buying it because I don't have much going budget wise. Can I do the same drain and fill procedure to get the air out or do I bring the car up to temp and with gloves squeeze on the hoses till the coolant drops below the the neck and top off while idling?
I'm getting a bit annoyed because as I planned for struts ,the tranny code came, as I planned that ,had to get tires,oil changed and coolant drain/fill done... And my purge solenoid is ticking too,,
Old Oct 3, 2018 | 01:49 PM
Radiator
I'm cuurently in the process of chaning the radiator in my TL... Looking in the repair manual it says to change the O ring on fan switch C.... Is it necessary ? And if so does anyone know the size?
Old Oct 3, 2018 | 02:38 PM
Looks like the size might be 13.5X1.2. Look for it in "related parts" on the link below.
O-ring 91307-PZ3-000
https://www.acurapartswarehouse.com/...3-pge-a01.html
Old Oct 3, 2018 | 05:46 PM
Is there anyway I can get a size like that at the hardware?
Old Oct 3, 2018 | 06:28 PM
It's worth a try if you can't wait.
HomeDepot
Ace Hardware
Northern Tool
Specialty Plumbing shops in your local area.
Old Oct 3, 2018 | 07:00 PM
It's a $1.50 part but shipping is 15 bucks.. I don't think that route is where i wanna go. and is the measurement in millimeters?
Old Oct 3, 2018 | 07:30 PM
Wheew!! What a relief.. Just went back downstairs and unscrew the cork that covers that sensor hole and found a o ring on it... Hopefully its the same size and I can use it..
Old Oct 3, 2018 | 08:31 PM
My new radiator**
Old Oct 3, 2018 | 09:05 PM
Iggy's Avatar
Yes, millimeters. 91307-PZ3-000 is a Honda number so if you can't find a 13.5X1.2 O-ring at the hardware store try hitting up your local Honda parts dept.
My guess is the O-ring that came with the new radiator will work just fine.
huxley
1G TL (1996-1998)
Jun 29, 2011 03:27 PM
3.5RLv-tec?
1G RL (1996-2004)
Oct 24, 2010 12:28 AM
libert69
Jul 15, 2009 11:16 AM
bmterp
Sep 7, 2005 11:38 PM
