quick question on timming belt
any time now would be good. dont go in a panic cause your over the recomended change time, but iff you can afford to any time soon would be good.
at teh same time get your water pump replaced too.
I have 170,000 on mine, and have inspected it a couple times and its in good shape.
Originally Posted by Daggra105
regardless of how it looks, change it out now. (from the opinion of a mechanic want-to-be).
Originally Posted by 02TL-S
I just had mine changed last week. I had them replace the timing belt, adjusters, idler, waterpump, accessory belts, coolant, and flush the brake fluid. My 02 has 108,000 miles on it at the time of service.
what happens if you don't change it?
does it break, does it screw up the whole engine. if you are driving, do you loose control of the car and die... does it explode... does it make your car faster...jejjejej,, you know what i mean.
Originally Posted by ou sig
dont leave us w/o the most important info!!!! how much was it!!!???
Belt
Adjuster, AutoM
Adjuster
Idler, Timing B
Water Pump
Belt, P.S. Pump
Belt, Compresso
Coolant
Total for this was $950.00 (Parts & Labor)
I also had the brake flush and tranny drain & fill.
Originally Posted by csilano
I believe the TL motors are interrupt motors so if the timing belt does go you could be looking at some big time repairs if a piston slaps an open valve.
This is the list for the timing belt package:
Belt
Adjuster, AutoM
Adjuster
Idler, Timing B
Water Pump
Belt, P.S. Pump
Belt, Compresso
Coolant
Belt
Adjuster, AutoM
Adjuster
Idler, Timing B
Water Pump
Belt, P.S. Pump
Belt, Compresso
Coolant
Do you have to go to a dealer? A friend of mine, took his to a mechanic, and got the timing belt replaced for like $400.
I think my brother had the timing belt in his Accord V6 replaced at the honda dealer for like $680 or something like that. Maybe you can get the TL's belt replaced at a Honda dealer
Belt
Adjuster, AutoM
Adjuster
Idler, Timing B
Water Pump
Belt, P.S. Pump
Belt, Compresso
Coolant
Belt
Adjuster, AutoM
Adjuster
Idler, Timing B
Water Pump
Belt, P.S. Pump
Belt, Compresso
Coolant
Originally Posted by fsttyms1
y some of you are so paranoid about a timing belt is beyond me. but oh well mine will wait
The cost of parts and labor for a new head when pistons and valves collide is just a "bit more" compared to the cost of replacing the necessary parts for a timing belt change.
Originally Posted by NJ Aegean 03
I wouldn't say it's being paranoid, just cautious... and they have every right to be.
US$950 for a timing belt change?! I remember changing it (twice) for my '91 Accord and it was C$450, including 15% tax!
Anyway -- it's important to change the timing belt 'cause it can cause serious damage to our engines if it snaps. Why cut a corner on the most important component of your car? I don't know if Honda engineers are being conservative on every 100,000km to change a timing belt ...
i have a 88 prelude with the original timing belt on it. the engine still runs strong and has 275k on it. im not going to replace that one. i want to see how long it will last
