quick amp wiring question
Sowi Roja u tiga now
Hey guys, im still a lil new here but i did try to search first. Anyway im goin to put in one twelve with an amp i was wondering about wiring the second amp and also the audio wires for the sub.
1st qeustion
if i remove the stock sub can i take the wires that were plugged into it and connect them to the audio source in on the amp. just didnt want to have to go to the back of the stereo system.
1.5 question are there rca outputs on the back of the head unit. if so can u guys provide a link to where i can get to the back of the stereo
2 question. can i wire the power wire (the small one for the amp to turn on with the car) to the stock amp so that it comes on with the other amp (not stock)
and where can i find the amp in the TLS 02 thanks
hope i made my self clear
TWAN
1st qeustion
TWAN
1. you will have to get a line out converter to convert the signal to RCA's
1.5.. No there arent.
2. You will have to run a power wire from the battery to the trunk for your power. While your doing that you might as well tap off the Drivers side fues panel for turn on. There are 2 spots on the back side of the fues panel that will accept a female butt conector that turn on with the car. OR you can tap into the amp turn on (believe its orange) from the factory amp for your turn on lead. Its mounted behind the rear seat back (have to remove the rear seat) passenger side
BoricuaTL
Apr 8, 2016 01:08 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
alan_rich
Sep 7, 2015 11:08 PM
