question on obd2 BT dongle
Old Jul 10, 2017 | 08:12 AM
Tomlintm's Avatar
im curious a friend of mine let me try out his bafx produce obdII BT scan tool with Torque Pro before i bought one which i do like alot but im trying to get the voltage reading from it and its giving me voltage (CM) No Data is there a extended PID's i need to get the reading from the ecu or what b/c thats what gauge i need most of all and its bugging me on why its not working
Old Jul 10, 2017 | 04:40 PM
Karanx7's Avatar
Unregistered Member
That's a pretty long run on sentence. Gave up trying to read it.
Old Jul 10, 2017 | 09:11 PM
Tomlintm's Avatar
let me guess you pretty much dont no what the PIDs i need are to get the voltage (CM) to work currect
Old Jul 11, 2017 | 02:18 AM
Karanx7's Avatar
Unregistered Member
Hmm, you still didn't use any periods. I'm not sure what a "currect" is, but I'm pretty sure you meant "know" instead of "no." But to answer your question, I'm very familiar with this car's ECU PIDs (or rather, lack of), as I had to spoof some of them for emissions. RIP XtremeOBD2.
Old Jul 11, 2017 | 06:30 PM
Tomlintm's Avatar
Oh sorry about my grammer i try to get my point across with little writimg as possable lol
So since there is a lack of PIDs for my car. Im guessing that my voltage (CM) in torque pro is useless then and i pretty much need a standalone volt gauge then. Unless u have another way to get it to work in torque pro im hoping
Old Jul 11, 2017 | 07:05 PM
Iggy's Avatar
I use both OBDLink and eCAR Pro and both show system voltage along with all the other standard stuff without any PID tweeks. I'm guessing you have a wrong setting somewhere for the connection. It's an older protocol like ISO9141 or 14230
Karanx7's Avatar
Unregistered Member
Grammar*. Writing*. Possible*.
Our cars are old, and our ECU PIDs are even older. Those OBD2 dongles with apps are really meant for newer cars. I believe our car does have a PID for voltage (I think I can get a live reading from my bigger scanner, but not 100% sure anymore), but it's probably an older format that the app won't recognize.
Either way, the voltage is kind of useless. I have a voltmeter gauge (mainly to just fill up the empty spot on my 3 pod A-pillar), and it was only every useful for letting me know my battery died.
Old Jul 11, 2017 | 07:17 PM
Tomlintm's Avatar
i may have to buy in to ecar pro b/c from what your saying that torque pro doesnt have are PIDs with out a PID tweek lol
Old Jul 11, 2017 | 07:22 PM
Tomlintm's Avatar
well its actully kinda important in my car b.c i run 3 batteries to run my sound system in my car that why i need it so bad lol. but im thinking that torque pro doesnt have the required PIDs in the app it self to run it so i may have to buy in to eCar Pro like the guy above said he was using
Old Jul 11, 2017 | 07:41 PM
Tomlintm's Avatar
alittle update i tryed eCar Pro i didnt like the look and feel of it and i dont think the battery gauge was even working at all plus i need a digi read out not just a needle thats a important thing to have unless it was analog with numbers but the one that was on ecar didnt have number or a digi read out only a needle
Old Jul 11, 2017 | 08:19 PM
Why don't you just get one of those voltage meter that plug into your cig adapter?
Don't those exist?
Or don't some sound systems have voltmeter built in?
Old Jul 11, 2017 | 09:22 PM
Tomlintm's Avatar
Don't those exist?
There are such things but i dont trust them plus analog voltmeters are more accuret
99 % of amps do not have built in volt gauges
Old Jul 12, 2017 | 06:51 AM
Iggy's Avatar
You have some kind of setting wrong or a bad OBD reader. Every app I have tried reads and displays voltage just fine.
Old Jul 12, 2017 | 01:45 PM
Tomlintm's Avatar
well its the bafx products obd2 and its my buddys that let me borrow it to test out on my car and he uses it on his ford f150 and it read his Voltage (CM) just fine which make no sence to me on why it doesnt like my car
what obd2 reader do you use maybe it just the reader it self that is having trouble reading my cars ecu
Old Jul 12, 2017 | 02:26 PM
SuperGreg's Avatar
Pretty sure my BAFX OBDII scanner reads the voltage, but I can double check later when I'm in my car.
Old Jul 12, 2017 | 02:56 PM
Tomlintm's Avatar
yes please and if so please post how you have torque setup so i can have my voltage read out but remeber there is 2 voltage readouts 1 is voltage (CM) which i need and 2 voltage (OBD2 Adapter) which is what the adapter it self is using im thinking
Old Jul 12, 2017 | 03:17 PM
Iggy's Avatar
I use the OBDLink MX and LX bluetooth.
Old Jul 12, 2017 | 04:43 PM
Tomlintm's Avatar
and u use it for the 2003 acrua 3.2tl non s type currect
Old Jul 12, 2017 | 05:04 PM
Iggy's Avatar
02 TL-s. Same as yours as far as OBDII is concerned
Old Jul 12, 2017 | 05:20 PM
Tomlintm's Avatar
oh ok i will deffently get the obdlink lx then since its working for you
Old Jul 12, 2017 | 07:05 PM
Iggy's Avatar
just be aware that the OBDLink MX and LX bluetooth are for Android and Windows devices, NOT the Iphone. If you want iOS support you have to get the MX wi-fi
Old Jul 12, 2017 | 07:25 PM
Tomlintm's Avatar
yuck iphones are trash android all the way lol
Old Jul 12, 2017 | 07:55 PM
Iggy's Avatar
^^ hehe. I agree
prepreludesh
18
Apr 13, 2011 08:54 AM
