Question about "Screen Saver" on Navi
Old Dec 9, 2001 | 12:46 PM
Lauderdale TL's Avatar
As most of you are aware, when the Navi is not operating (i.e., when you do not press anything after it first loads up), a screen saver appears. Just yesterday, the clock, which normally was in the bottom right corner of the screen (as it is when you are using the Navi) now appears in large numbers across the center of the screen saver screen. Please let me know where your clock appears when it is in this mode. Its unusual since as I said before, the clock always was in the bottom right of the screen.
THanks
Old Dec 9, 2001 | 01:31 PM
thebeaud's Avatar
It's actually up to you. If it's in the lower right hand corner, just press it and it'll move to the center and be displayed a bit larger. Press it again, and it'll revert back to the corner.
I actually leave it in the middle, as I prefer the larger display.
Old Dec 9, 2001 | 01:34 PM
I see, I didnt realize that I had done that. Thanks for your response.
Old Dec 9, 2001 | 02:07 PM
thebeaud's Avatar
That's what we're all here for!
It'd be cool if there were some "true" screensaver options, huh? Or if it could be hooked up like an equalizer display - might be too distracting, but would be kind of neat....
Old Dec 9, 2001 | 04:48 PM
pianoman41's Avatar
Does anyone know if the "starfield" is randomly generated each time or is it a preset image?
Old Dec 9, 2001 | 04:49 PM
pianoman41's Avatar
Also, is the display type used for the navi prone to screen burn-in? I thought those types of displays didn't have to worry about burn-in.....
Old Dec 12, 2001 | 07:43 AM
Road Rage's Avatar
Not a Blowhole
It is set, and since this is not a CRT, burn-in is impossible.
I think the screen saver should say:
"WATCH THE ROAD, MORON!"
datadr
Sep 12, 2015 09:12 PM
Gianni Formica
Sep 7, 2015 08:28 PM
yahelou
Sep 6, 2015 09:12 PM
Rexorg
3G MDX (2014-2020)
Sep 3, 2015 12:40 PM
SUPRMN84
Sep 2, 2015 11:50 PM
