Problems with WW kit, need help
Old Mar 20, 2001 | 03:59 PM
3.2-TL's Avatar
Post Problems with WW kit, need help
I installed my kit a month ago and on the side towards the end is falling apart. I don't know if i gotta put a screw or something to hold it together. Don't have any instructions as to go about this because the instructions it came with were for a 300zx. The body shop who installed it sayed that there was going to be a gap, but now the gap got bigger and its loose. Anybody have similar problems installing the kit and what did u do? please help!
Old Mar 20, 2001 | 04:23 PM
SilverBullet29's Avatar
Post
You might want to use a stronger double stick tape like 3M... Also your ends should be screwed on to where the mud guards would be on the front. I think you should take the kit off clean the part that hooks on to the car & just replace the double stick tape... It's time consuming but worth doing if you still want your kit on...
Old Mar 27, 2001 | 08:04 PM
Edr0e's Avatar
Post
I had no problems with my kit. You just have to make sure you align it correctly so that it fits perfectly on the back. If its too high there will be a gap in the fender. If too low it won't fit period. There should be two screws properly drilled on each side into the fender. Make sure you use the 3M adhesive before stickin the tape on.
cycdaniel
Dec 17, 2019 10:58 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
Zonian22
Nov 14, 2015 01:20 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
Zonian22
Sep 2, 2015 08:19 AM
