Problems
Problems
Group,
I just received the window recall but do not notice a window problem. I do see a problem in two other areas though.
1. The remote trunk release is very weak, It will only unlock the rear lid from 1 ft or less and only if I am aiming it at the center of the lid.
2. The power passender seat only moves front to back, no height adjustment like the driver seat.
Anyone experience similar results
99TL here and the Remote Trunk release is a pain in the ass! You have to right up on your trunk and pressing the trunk release button with a good amoung of force, for it to pop. My remote has always been this way since the start and not due to a low battery.
I have seen other cars, that you just hit the trunk release on the remote and it pop open so easily. Truly one touch.
Guest
Posts: n/a
Try holding the button until the trunk pops open. I was having the same problem because I would touch the button and let go right away. The same with the tripometer reset button. You need to actually hold the button down until it resets itself. It's not just a quick one second touch - - try it! Otherwise, my trunk opens fine wherever I aim at it.
Guest
Posts: n/a
Anyone experience similar results[/B]
MB-Fanatic w/TL-S
1 Post
You have to hold down the "Trunk Release" button in order to pop it open. It's a safety feature that eliminates the chance of pop open the trunk accidentally. Hold it down 'til Trunk pops....
I can always pop up the trunk 3-4 car away...
Andy Kuo
'92 Mercedes-Benz 400SE
Pearl Grey/Black
'02 Acura TL-S
Satin Silver/Ebony, w/out NAV
Andy Kuo
Pearl Grey/Black
'02 Acura TL-S
Originally posted by darthferd:
It sounds like the new TL was very poorly built. My 99 Maxima never gives me problems. To bad you all wasted $30000.
I was curious and tried my trunk release after reading the initial post. I paced out 100' and it worked everytime from that distance, without even aining it at the car. I didn't bother going any further.
Feliz
98 Acura CL, primrose
2002 TL-S, silver
Feliz
2002 TL-S, silver
Here's a trick that may help people get distance out of their remote. Try holding the remote to your chin then press the trunk release or the unlock/lock button. You see holding the remote to your chin makes your body act like an antenna increasing distance.
Give it a try it works.
Retired MOD
1 Post
The trunk release on the remote was done on purpose. You have to hold it for about 3 to 4 seconds. This was done in case you acidentally press the buttom and left the trunk open. They didn't do this on the lock/unlock of the doors, because if you acidentally press it if you don't open the door it will lock after about 30 seconds. Something that you can't do on the TL trunk.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
