Problem with painted calipers
Old Jun 9, 2001 | 07:17 PM
96TL's Avatar
Ex-Mod
Post Problem with painted calipers
I was cleaning my wheels with Armor-All wheel cleaner today and when I sprayed the rim with the hose on full blast a small piece of paint came off my caliper! I painted them with High Temp Rustoleum which is good paint and I gave them a nice coat. The rest of them are fine. Now what? If I just touch up that spot it will be noticable. I dont want to give it a new layer of paint because I doesnt look good when its too thick. Is there any way to strip off the paint so I can repaint it?
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by 96TL on June 10, 2001 @ ]</font>
Old Jun 9, 2001 | 07:59 PM
Lightbulb
Get some "very fine" grit wet-sanding paper (made for metal). Soak it for a while in water then use that paper to lightly smooth out that chip. Then just repaint that one spot. Should turn out good
BTW - 96 TL - I used a Dremel to make a hole in the very bottom of my center console to run the switch panel wiring.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by TL Daddy on June 09, 2001 @ ]</font>
Old Jun 10, 2001 | 01:39 AM
96TL's Avatar
Ex-Mod
Post
Thanks TL daddy, I'm gonna try that tomorrow. I plan on doing the same thing you did with your switches probably next week.
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
merc009
Oct 3, 2015 12:59 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
