Problem with painted calipers
Old 06-09-2001 | 08:17 PM
96TL's Avatar
Ex-Mod
Post Problem with painted calipers
I was cleaning my wheels with Armor-All wheel cleaner today and when I sprayed the rim with the hose on full blast a small piece of paint came off my caliper! I painted them with High Temp Rustoleum which is good paint and I gave them a nice coat. The rest of them are fine. Now what? If I just touch up that spot it will be noticable. I dont want to give it a new layer of paint because I doesnt look good when its too thick. Is there any way to strip off the paint so I can repaint it?
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by 96TL on June 10, 2001 @ ]</font>
Old 06-09-2001 | 08:59 PM
Lightbulb
Get some "very fine" grit wet-sanding paper (made for metal). Soak it for a while in water then use that paper to lightly smooth out that chip. Then just repaint that one spot. Should turn out good
BTW - 96 TL - I used a Dremel to make a hole in the very bottom of my center console to run the switch panel wiring.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by TL Daddy on June 09, 2001 @ ]</font>
Old 06-10-2001 | 02:39 AM
96TL's Avatar
Ex-Mod
Post
Thanks TL daddy, I'm gonna try that tomorrow. I plan on doing the same thing you did with your switches probably next week.
Oakes
Wash & Wax
11-12-2015 10:34 PM
CheeseyPoofs McNut
10-11-2015 12:25 PM
merc009
10-03-2015 01:59 AM
DwDrummer
5G TLX Problems & Fixes
09-14-2015 09:20 PM
HOWELLiNC
09-10-2015 02:39 PM
Quick Reply: Problem with painted calipers
