This is the problem with OT!!!
Old 03-09-2001 | 06:43 PM
adamyankee's Avatar
Post This is the problem with OT!!!
I posted this 24 hrs ago http://www.acura-tl.com/ubb/Forum9/HTML/000771.html and I have seen some posts go unnoticed before, but this question is definitely up someone's alley.
If I posted it here, someone would have moved it to OT. So I made the decision and posted it in OT myself, and I doubt anyone even saw it.
AT least Tim's taking care of it by redesigning the forum. Thanks.
1999 Firepepper Red
Under Body Kit/Rear Wing Spoiler/26 Piece Wood Grain Console/BurlWood Shift Knob/
30% Smoke Tint/Comptech Sways & Springs (not installed yet)
More Pics
Old 03-09-2001 | 06:54 PM
Shoofin's Avatar
Post
Ya think maybe nobody can answer your question?
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Old 03-09-2001 | 06:58 PM
adamyankee's Avatar
Red face
With the answers I've seen answered here, I'm sure there are several members who can. I just don't think those guru's visit OT as much as the main discussion. Plus, I have seen members post that they don't know, just like you did, Ed. No responses seems fishy on a car related question, on a car related forum.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by adamyankee on March 09, 2001 @ ]</font>
Old 03-10-2001 | 11:25 AM
Red Hot TL's Avatar
Post
dude, it's TL related forum... only talk about TLs there, and if you do want to get into some details about things like that, it's great that some ppl can answer it here for you, but you could also try to search on the internet. also, people visit the TL Discussion the most because people post everything there, and we're having a problem of having too much posts there in a short period of time, that's why moderators are moving posts that are not TL related to OT and other appropriate forum.
Moderator on Acura-TL.com Forums
2000 Red Hot TL w/o nav
Burlwood Trim and Shift Knob
Wood Trim Set
Gutter Guard Grill
Nebraska Legal Darkest Tint
Goodyear Eagle HP Ultra Plus 225/55/16
Photos Of My RED HOT TL
Old 03-10-2001 | 01:36 PM
adamyankee's Avatar
Post
I don't disagree with you guys and I have no intention of flaming the moderatorss at all. But since Tim will redesign the site this way, I can't say I am wrong or that I am alone. I was just stating that there is a catch22 going on here, and I'm glad that Tim took care of it.
It's all good ma brothas.
Old 03-10-2001 | 01:54 PM
Guest
Guest
Posts: n/a
Post
Well first off you need to understand what the offset of a wheel means.
In a positive offset layout, the hub mounting surface is torward the front or outside of the car. In a negative offset the hub mounting surface is torward the back, or near the brakes. A zero offset would be mounted even with the centerline of the wheel.
Now with a front wheel drive layout, the wider the tire is, it must be accomodated with a higher wheel offset to prevent to ensure the wheel "tucks" and does not rub. This limits the maximum width a tire can be correctly installed in.
In a rear wheel drive layout, its safe to assume the car has already been stamped with performace in mind. Since the rotating mass is not near the engine bay, and weight transfer will be maximized to the wheels moving the car, wider tires will typically be needed. You need to understand suspension basics (which I'm not ready to get into today) to know that for every action there is an equal and opposite reaction. In a sense, negative offset rims (deepdish), allow a few positive factors like wheel strenth under high power, and straight line suspension engineering. With a shorter rear axle wider tires can placed in the back as well, requring the negative offset. (Just look at a F1 Car).
I dunno if that makes sense but its a bit hard to explain, anyone feel free to correct me where applicable.
Originally posted by Einstein:
"No torque for you!"
Old 03-10-2001 | 02:21 PM
adamyankee's Avatar
Post
BAM!! Thanks TorqueNazi. Did you see my post in OT before you read it here?
I understand Offsets, so your answer makes perfect sense.
That's all I wanted to know.
Case Closed.
Old 03-10-2001 | 02:23 PM
Guest
Guest
Posts: n/a
Post
I have 76 posts since August 01, 2000, so I dont cruise the other forums too often.
SidhuSaaB
05-30-2020 01:40 AM
Fool
03-10-2016 09:42 PM
12vancover
10-16-2015 01:04 PM
Matthew Purpura
09-25-2015 07:10 PM
MikeJM310
09-24-2015 08:24 PM
Quick Reply: This is the problem with OT!!!
